Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
2/3RZ Swap Header for 84-85 Toyota's
Old 05-20-2014, 01:49 PM
LCE_Performance's Avatar
2RZ/3RZ Swap Header for 84-85 Toyota Hello, Ladies and Gentleman.
This is Andrew at LC Engineering.
We have come up with an answer to your exhaust manifold problems with the Factory manifold.
LC Engineering has made a new swap header, that will get rid of the broken, cracked, or smashed cast exhaust manifold.
LCE Engine Swap Header Pickup, 4Runner To Newer 2RZ/3RZ Engine
(NOT smog legal)
Everyday more and more people are swapping newer engines into their old trucks, LCE has developed a totally new header that will work with your newer 2RZ/3RZ and will also fit on your old style Toyota Pickup truck or 4Runner.
This is a high quality header designed to get the most horse power for your Toyota 2RZ/3RZ. There are other headers on the market but none will come close to the LCE Headers in terms of horse power and torque gains. This header kit will come with new OE the gaskets needed for install.
All the same quality components used in our 22R/RE line are now available for your 2RZ or 3RZ engine. Our header kits for the 3RZ are made from 1-5/8" 304 stainless steel tubing, 16 gauge .065 wall, and feature 1/2" thick flanges at the head and 3/8" thick flanges at the collector. 3RZ header has a 2 1/2" collector to bolt to the factory catalytic converter. For the best performance, our headers are ceramic coated for long-lasting great looks and lower under hood temps. Kits include all gaskets needed for proper installation. LCE 2RZ/3RZ header kits are direct fit on single catalytic trucks only. Trucks with dual catalytic converter applications will require modification to use LCE's header kit.
If you have any questions feel free to PM me and I can answer any questions that you might have
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
Outsane
07-15-2015 05:01 AM
puffin04
07-10-2015 09:17 PM
Quick Reply: 2/3RZ Swap Header for 84-85 Toyota's
