fox air shocks
heres a wright up on them fox air shocks . they replace you springs
Sounds like way too much hassle and work unless it's for a serious trail ONLY truck that needs a special setup like that. Not very practical for the everyday off-roader. Not to mention the cost of the nitrogen setup, tuning and rebuilding. Ugh....
I have a front 3-link with fox 2.0's as my wheeler and dd. They are great. The trick is the setup. I am running 330ml of 5w oil and 380 psi of nitrogen. Airshocks handle compression very well; however, they do unload rather quickly. It will require some experience on the road before you feel 100% comfortable. A swaybar will likely help. I do not believe that I would run front and rear airshocks...
Blamalam
03-12-2022 07:34 AM
punks_is_4x4
08-21-2015 01:35 PM
Luvmeye22re
08-04-2015 03:53 PM
terminator
07-27-2015 07:13 PM
