CAM sensor
CAM sensor
anyone know why these replacement cam sensors for 2uzfe come with a metal plate over the sensor? some replacement brands have it while others do not. would seem odd to go through the trouble of drilling and tapping holes just to hold a protective cover, and to boot the cover is not some scrap metal, seems to be die pressed into shape, is very thin, and is non-magnetic.
update: Beck/Arnley says its an aluminum protective cover and is used in service (B/A says Toyota added this cover for a heat problem they needed to solve). from the looks of the sensor i took out of my 2006 gx470 this cover will also help protect the sensor from "wind" damage, more so say for Tundra that is used in more work capacity, etc.
Blamalam
03-12-2022 07:34 AM
djohnson13
09-04-2015 12:35 PM
