Last edit by: IB Advertising
- Toyota Tundra Drive Shaft Review and How to Install Drive Shaft
Combination of review and how-to.
'03 Tundra Payload increase
Has anyone out there increased, or know of anyone who has, the payload capacity of a Tundra? I'm not talking about adding air biscuits or quick fixes like that. I'm talking about an axle swap or something that would truly increases capacity.
Why?! A fabricator asking someone why they want to customize their truck? No comprende.
Just kidding.
Short answer: Because its there.
Long answer: None of the major manufacturers called me to ask what I want as an ideal truck.
I love my Tundra; cab size, comfort, quality, best d!@n sun-visors in the business, runs great and reliable. BUT, I would like to be able to fit a little more firewood in the back before I'm overloaded. Also, it would be nice to have a few more selections of usable slide in campers.
While I have your attention, here's my pipe dream. Keep in mind the current truck(not the one in my avatar, thats another project all together) is an '03 extra cab Tundra. Yank the cab, extend wheelbase to that of a normal extended cab long bed(think Ford F150 extended cab long box), beef up the rear axle and put an 8' flatbed on it.
Could it be as easy as getting a hold of a drive shaft from a standard cab long bed Tundra, moving some suspension mounts backwards and bolting on a different, beefier rear axle and mating drive shaft to said bigger axle? Let me know what you think.
Just kidding.
On a side note, I have a personal best of 2300 lbs of pea gravel I hauled for a 3 hour tour around DC (40 mph), the Airlift aircells helped do that....
Good point. Maybe a drive shaft from a domestic extra-cab long bed with corresponding axle and suspension. Just pipe dreams at this stage (have other projects to finish first) and was wondering if anyone else had pulled it off.
Frame isn't up to the task. Unless you plan to box it from the b-pillar back, adding 1-ton and adding 1-ton axle/suspension, you're out of luck froma payload perspective.
Thanks for the input rockota.
Don't think I need/want full 1ton capacity, 3/4ton would be more than enough.
Like I said earlier, this is an idea/pipe dream, I haven't done a lot of research as of yet. What is the limitation of the current frame in regards to increased payload? Is there any reason I couldn't box it from the b-pillar back and extend it to get an 8' bed with the current extra cab configuration? WabFab (hope I didn't scare you off), what do you think?
Ultimately what I would like to do is to add an old Sunrader camper coach to the back and end up with something more reasonably sized (space and power wise) than a Toyota MH but smaller than an Earth Roamer or Tiger CX.
live4soccer7
05-11-2016 06:52 PM
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
