Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
prerunner fender question
Old 12-23-2016, 02:26 PM
AnimalGuy's Avatar
Who makes the widest prerunner fenders? My tires will be about 9 inches proud of my fenders. Its going to be just a little taller than stock with 30 inch tires.
Thanks!
Old 12-23-2016, 08:43 PM
Robert m's Avatar
Jesus, what are you running for suspension to make it that wide?
No one makes fenders that wide. I think the widest replacement fender is like 4'' wider. The only thing that's wider than those fenders is a tundra 1 piece conversion
Old 12-27-2016, 07:13 AM
AnimalGuy's Avatar
This is a 2wd street truck. I have a 94 Mustang front suspension and a Cadillac Eldorado drivetrain/suspension in the rear.
The front is 72 inches wide, The rear is 85 inches. The frame is 6 inches off the floor, 33 inch tires in the rear, 30 in the front.
Old 12-27-2016, 07:37 AM
AnimalGuy's Avatar
Old 01-13-2017, 10:59 PM
92 Toyo's Avatar
I'm so confused on what you're building here, are you secretly red green?
Old 04-07-2017, 10:32 AM
AnimalGuy's Avatar
It will be a little milder than this one.
Old 04-07-2017, 10:55 AM
Fossilized
Staff
dropzone's Avatar
why not get another donor body, cut and section the two together so you get the coverage you need
Old 04-07-2017, 01:37 PM
flg8r22's Avatar
However you do it, I can't wait to see it. If you want to keep the original body lines, extend both sides of your hood to your desired width. This would be pretty easy as both sides are basically flat from side to side and a little crown from front to rear. Change the mount location for the factory fenders and call it done
Old 11-11-2018, 08:32 PM
Grey_Matter's Avatar
i have a Hellion Industries tundra one piece front end, my truck is 85 inches wide, fiberwerx might be wider, but why?
