Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed
Old 09-08-2015, 05:01 PM
justdifferentials's Avatar
Here is a vehicle we built a few years ago, but I figured some of you would like to see the work we put into it! We recently updated the Tundra with some new parts and a whole new look.
Before:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-gbqhcpul.jpg
And after.
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-rilbfq2l.jpg
-2007 Tundra Crewmax 6 seat, Stretched 12” to accommodate 6.5’ bed
-Nitro Gear 4.88 Ring & Pinions, Auburn Gear Pro Limited Slip Rear Diff
-2015 TRD Pro Facelift with OEM hood, Grille, headlights, tail lights, Tailgate by Toyota USA
-TRD Supercharger & Wheels
-Total Chaos Long Travel Front and Rear Suspension
-Icon Vehicle Dynamics Remote Reservoir shocks with secondary Bypass shocks
-Custom long travel airbag setup with reinforced frame and crossmembers, and rear receiver bumper by Justdifferentials
-37” Nitto Trail Grapplers
-SDHQ Fiberglass Prerunner Bedsides and Fenders and Prerunner front bumper
-Warn XP9000 Winch with Synthetic rope and Factor 55 Prolink
-Doug Thorly Headers & Mid Pipes
-Rigid Industries Lights
-Custom leather interior, sunroof, navigation system
-Bodywork by Mission Creek Autobody
We sell all the products that are on the truck and can provide the full deal on installation, with exception of the frame stretch / bed conversion.
Vehicle Specs:
-2007 Toyota Tundra Crewmax 5.7L 4x4 SR5 Radiant Red
-Frame Stretched 12" and 6.5 foot bed conversion, as crewmax typically has only a 5.5 foot bed done by Precision Bodylines in UT
-6" Pro-Comp Stage II lift, 35" inch Nitto Trail Grapplers, XD Monster 18" wheels
-Front Air Locker, Compressor kit, ARB Sahara bar Winch Bumper, IPF lights
-Auburn Pro Series rear LSD unit
-TRD Super Charger for the 5.7 L
-Transfer Flow 46 Gallon Fuel Tank
The purpose of this build is to show that the Tundra can be a true contender as a real Fullsize truck, for towing, etc.
-The Tundra Crewmax is a great truck, but the 5.5' factory bed is too short for many people. The Access Cab has a 6.5' bed which is great, but a smaller cab. Why not have both? So, the frame has now been stretched 12" to fit the 6.5' OEM bed. Toyota should totally offer them this way.
-The TRD Super Charger is a key element to showcase the power potential of this truck. This will be installed by the experts at Town Toyota in Wenatchee, WA.
-The Tundra has lots of power but fairly light in the back. We all know the factory traction "Electronic LSD" is more of POS than POSI! I could not move an inch when attempting to pull a boat out at the ramp when in 2WD. Now Auburn Gear who is one of the most popular aftermarket and OE traction device manufacture released a Pro Series LSD for the Tundra! This is the same, PROVEN design they've had for years, but available for this new application. Now the Tundra will pull the boat out at the ramp in 2WD without a slip! Also can pull away from a stoplight on wet pavement without slipping and electronics coming on! This is a relatively inexpensive mod for a HUGE result! The Auburn really is the best one for the rear of a Tundra, because its smooth, quiet, and provides real world advantage even for regular daily driving.
-With the Auburn we were no longer lacking in the traction department when towing or daily driving, but I'm a diff guy, and I want the best diff setups I can. This is where the ARB Air Locker came in. The Air Locker is great for a front-end as you can turn it on for 100% locked traction, or turn it off for an std open diff when you dont need it and have full maneuverability. The ARB High Output compressor runs the locker, but also can fill tires, this is very handy when your out in the woods.
-We wanted to have a winch mounted cleanly, so we chose the ARB Sahara Winch Bumper and had it color matched. They look great and the style cant be beat. The ARB bumpers are also quite functional, strong, and are a very proven product. I've had them on several of my own vehicles and they have saved me from lots of potential damage. They also safe and are engineered and crash tested to be fully compatible with the air bag system. We opted for the optional fog-light kit that goes in the bumper and a larger set of IPF lights to mount on top of the bumper. The fog lights were a breeze we just used the OEM toyota turn signal switch and relay and it works great! This sr5 did not have OEM fog-lights, but the wiring is still there! We now offer these parts too.
-The Lift, Tires and Wheels, well - this is mainly for additional clearence "offroad" Well, really, They do look great and drive great too, but the Locker & LSD really work the magic. The truck sits pretty high, so for the passengers that are height challenged we installed the AMP research Power steps. The steps are an eassy bolt on install, and retract to be hidden when you shut the doors, and drop down to provide a nice low step to get in! These steps aren't really too far off of the cost of other aftermarket steps and a great addition for taller lifted trucks.
-Anyone who tows with their Tundra for any distance will probably not be too happy with the fuel range. If you have to gas up every couple hours on the road it gets pretty old fast. So we called our aftermarket fuel tank supplier Transfer Flow, we know they make top notch products, and got a 46 gallon replacement tank on the way. This nearly doubles the capacity of our stock tank!
Ok now for some pics:
The Monster 10.5" differential got Nitro Gear & Axle 's 1st set of T10.5-488-NG 4.88 R&P gears:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-lbwplxhl.jpg
And an Auburn Pro LSD, now the 500+ HP can get to the ground, much more beef to this one too:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-p7dhqojl.jpg
Roy at Town Toyota installed the huge Toyota Racing Development Supercharger:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-cieib2ml.jpg
Time to box in the floppy tundra frame:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-cktfib2l.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-qca4ut5l.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-3ppx3cql.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-sc94invl.jpg
Old 09-08-2015, 05:03 PM
Toyota decided to use a huge 10.5 which is great. but then they put it in a housing with minitruck axle tubes:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-s5teqwwl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-allqurpl.jpg
Gussets welded and painted up:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-hgdboggl.jpg
Added in a B&W trailer hitch:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-rebqt5zl.jpg
Airbags to keep the truck level under load as well:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-cqerpbkl.jpg
Frame stretched and boxed:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-zuncymkl.jpg
Added a Transferflow 46 gallon tank:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-iqtoqhkl.jpg
Getting off the road:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-cy0pvtil.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-z17epvdl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-fq7kpoxl.jpg
Old 09-08-2015, 05:12 PM
We have made some big changes to this truck. Stay tuned in the next few days and I will get some more photos and details posted up. Here is a teaser for now.
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-wt1xbiw.jpg
Old 09-17-2015, 06:03 PM
Here is an updated spec list:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-xfrbl6jl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-3ezj0djl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-ii50pq7l.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-rj46yxql.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-2bxsatml.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-dol157pl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-dbuqrohl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-a0rkso2l.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-rqno0fdl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-mycyyril.jpg
Old 10-16-2015, 08:58 AM
CW Wraps did a great job on the Tundra, we will be debuting this truck off at SEMA in a few weeks!
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-c7y5ugf.jpg
Old 10-18-2015, 02:17 PM
84 yota dude's Avatar
Looks killer! Was the purpose of stretching the frame for the bigger bed? And nice looking 3 link 4runner in the background
Old 10-24-2015, 06:21 PM
Yes it was and thank you!
Old 11-02-2015, 01:09 PM
We used the Tundra for our newest ad in the back of LFTD & LVLD Magazine. Check it out if you see it on newsstands. If you are going to make it to SEMA come check out the Tundra!
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-foei2hil.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-klyvjbql.jpg
Old 02-20-2016, 02:09 PM
We recently uploaded a new blog article, A Sema Truck That Wasn't, about the Tundra. Check out the link and read about our adventures and a few hiccups leading up to SEMA.
Once the weather cleared up enough, Carl took the Tundra to the dunes to test out all the suspension upgrades. Here is a short video of how it went:
Old 02-22-2016, 07:04 PM
Here are some more pics of how it sits now:
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-pkjdbn9l.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-zd2o44hl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-qohdxojl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-7umb8rrl.jpg
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-nwdfuvxl.jpg
Old 02-22-2016, 07:07 PM
Badass rig
Old 08-25-2016, 05:32 PM
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-7bjjaqvl.jpg
The Nitro Tundra has been a very long lived project for us and gone through an evolutionary process from mildly modified with a stretched chassis to a full update last year for the SEMA show in Las Vegas. It’s been a great truck and is a ton of fun both on and off-road.
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-fqmaz0q.png
Summer 2015 we swapped 2015 TRD Pro Tundra sheet metal front and rear including the lighting combined with SDHQ pre runner style fenders/bedsides for more clearance in the wheelwells. Add in a combo of Total Chaos long travel control arms, custom Atlas springs (now sprung under with floating air springs for load capacity) and bypass Icon shocks all around and this rig was clearly build for more than just show. An SDHQ front bumper mounting 3 ARB Intensity lights and Rigid fogs improved clearance without sacrificing the Warn 9.5XP winch or nighttime illumination. Rear bumper and hitch assembly (it still tows regularly) were custom fabricated in house. Finally, new Nitto 37″ Trail Grapplers wrapping black TRD wheels put the power to the ground.
This wasn’t exactly a stock rig when we started. The earlier build included the aforementioned TRD Supercharger, ran a color matched ARB bullbar, upgraded suspension and a fully boxed rear frame section lengthened 12 inches to accommodate the long bed instead of the standard tiny box as this Crewcab was equipped from the factory. It was a good, usable combination with somewhere north of 500HP, but visually not very unique.
Here it is before:
And after.
With the weather finally improving enough to go have some fun we took the Tundra to the only dunes in our area and let it off it’s leash for the first time since the rebuild. The Auburn Pro LSD unit and Nitro 4.88 gears easily took the power from the Supercharged V8 without issue and the Doug ThorleyDoug Thorley Headers headers and pipes sound amazing at full song
. The truck is an obsolute blast in the rough stuff as the suspension sucks up big and little whoops at ridiculous speeds for a daily driven street truck and sounds awesome doing it. Add in all that horsepower on tap with its supercharger whine and we’re really pleased with how this project has turned out. Nice on the street, still tows toys well and is extremely capable in the dirt.
Specs:
Sponsors: Nitro Gear, Toyota USA, Icon Vehicle Dynamics, SDHQ, ARB, Auburn Gear, Nitto, Warn, Total Chaos, Amp Research
Wheel Base: 160”
Track Width: 88”
Over all Length: 21’8”
Over all Height: 79”
Type: Toyota 5.7 3UR-FE, TRD Supercharger
Output: 550HP
Engine management: Bullydog / Toyota
Exhaust system: Doug Thorley longtube, magnaflow muffler, custom piping
Fuel Tank: Transfer Flow 46 Gallon
Transmission: ITP High Performance Valve Body
Differential gears brand: Nitro 4.88 (world’s first set!)
Birfields/CV brand: OEM, w/ Total chaos extended shafts
Locker-Rear: Auburn Pro LSD
Suspension Total Chaos Long Travel front and rear
Shock absorbers, f/r: Icon Double Bypass, (dual front),
Springs, f/r: Eibach front, Atlas rear
Sway Bars: Curry Rear antirock
Bump Stops: Icon hydraulic rear, Timbren front
Seats: Classic Softrim Leather, heated seats
Front bumper: SDHQ Prerunner
Rear bumper: Custom Krys-Fab
Sliders: Amp Research power steps
Skid plates: SDHQ
Winch: Warn XP9000
Winch rope: Warn Synthetic
Other safety/Interior gear:Factor 55 Prolink
Brakes: Pads/Shoes, f/r: TRD Pads, Crossdrilled, slotted rotors, Stainless lines
Tires: Nitto Trail Grappler 37/12.50R18/Toyota TRD Pro 18”wheels
Body mods: 2015 Toyota USA OEM Fascia, Tailgate. SDHQ Fiberglass Fenders and Bedsides.
Frame mods: Precision Bodylines 12” frame stretch to fit 6.5’ bed with crewmax. (Toyota only offers 5.5’ bed) custom boxing, additional crossmembers for airbag system.
Headlights: 2015 TRD Pro OEM
Paint/Graphics: OEM Radiant Red, w/ Nitro Graphics designed in house by our graphics guy, Aaron
Weight: 7200 lbs
Shop where work was done: Justdifferentials.com
Old 09-12-2016, 06:42 AM
The Long Travel Tundra up for sale, if you are interested please email Carl@JustDifferentials.com for more info. Please do not PM us on the forum! It is priced at $55,000.
Possible partial trade for
-Toyota Tacoma, Land Cruiser, 4Runner
-2014+ Subaru outback, Toyota Highlander or other Japanese car based AWD SUV.
Full spec list:
2007 Toyota Tundra Crewmax 4x4 123k miles on truck
-10,000 miles on New 5.7 Toyota 3urfe Motor
-TRD Supercharger, Doug Thorley longtube headers, Magnaflow / stainless exhaust.
-ClassicSoftTrim Leather & heated seats installed on Sr5 30/20/30 bench Seats 6 adults!
-Kenwood navigation deck, remote start, backup camera.
-Rebuilt diffs with Nitro Gear 4.88 Ring & Pinions, Auburn Pro LSD Rear Posi
-Set of 5 Nitto Trail Grappler 37/12.50R18 mounted on OEM Toyota TRD Pro Tundra wheels.
-Body style Update to 2015 TRD Pro with OEM Toyota hood, grille, headlights, taillights, tailgate, Fresh Radiant Red Paint on the whole truck, all professionally done.
-Front Suspension: Total Chaos Long travel with heim uppers for more adjustability, Icon 2.5" remote res coilover, secondary Icon Bypass shocks, timbren bumpstops, Extended axles to retain 4wd
-Rear suspension: Total Chaos spring under kit, Icon bypass shocks & hydraulic bumpstops, Atlas Springs, Total Chaos shackles, custom heavy duty long travel airbag kit, Anti-rock Torsion swaybar, reinforced, boxed frame, additional crossemembers, custom bumper built onto OEM Tow hitch receiver to retain towing capability
-SDHQ Front bumper, Fenders, and bedsides
-Warn XP9000 with synthetic line, factor 55 pro link
-IPF Intensity lights x3
-Rigid D2 Amber fog lights
-Oddessey battery, Amp Research Powersteps
-Fresh Line-x'd bed
-All maintenance done regularly, new TRD brake pads & Crossdrilled / slotted rotors
-Toyota OEM Bed divider, tie downs, rail system
-Trifold hard folding bed cover allows bed to be securely locked.
For more info and pics, check out this link: https://nitrogearaxle.wordpress.com/...rd-pro-tundra/
Old 01-18-2017, 03:04 PM
Awesome to see the Nitro Tundra on the cover of 4wd Toyota Owner magazine this month.
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed-rcxupdql.jpg
Old 06-11-2017, 08:36 PM
We have the Tundra listed for sale on Ebay. If you are interested in a solid truck that will do it all, check it out!
Full spec list:
-Fresh Line-x'd bed
urabus
11-10-2015 07:38 PM
ToyotaMD
11-09-2015 11:53 AM
Brodetski
09-30-2015 11:50 PM
ToyotaMD
09-22-2015 04:49 AM
ToyotaMD
09-07-2015 04:44 AM
Quick Reply: Just Differentials Toyota Tundra Crewmax w/ 6.5' bed
