Yota Techers I need your help
Old 07-02-2007, 03:29 PM
TJ_Shunk's Avatar
I have a 97 Runner and I am having an clicking sound on the passenger side of my steering rack. I can feel some sort of vibrations when the click happens if I touch the Tie-rod. The clicking is getting worse the longer it goes on. Any body have an suggestions as to what this is?
Old 07-02-2007, 05:13 PM
Skrillah's Avatar
I'm going to say its your cv's but it'd help if you gave a more thorough explanation of the problem and what you do that makes it make noise (i.e. turning the wheel, certain speeds?, etc.)
Old 07-02-2007, 06:44 PM
TJ_Shunk's Avatar
Ok. I got some more info..
It is only when turning the wheels and I can see the steering gear tube moving in it's mounting Grommet I have attached a picture to show as a referance...
Old 07-02-2007, 07:10 PM
Skrillah's Avatar
Do you have 4wd?
Old 07-02-2007, 07:15 PM
fortinbras's Avatar
When you say steering gear tube, are you referring to the tube that connects the left and right bellows? I'll take a look at mine tomorrow but as far as I know there should be minimal to no movement by that tube.
Old 07-02-2007, 07:51 PM
TJ_Shunk's Avatar
Yep, it is 4wd.
I would think it should have NO movement so that it is steering the wheels. If it moves, not all steering movement is getting to the wheels.
Old 07-02-2007, 07:52 PM
TJ_Shunk's Avatar
Originally Posted by fortinbras
When you say steering gear tube, are you referring to the tube that connects the left and right bellows? .
THe arrow is pointing at the tube in question. It is what houses the rack on the passenger side.
JonG85
01-18-2023 04:31 PM
LittleUgly
15
01-02-2020 01:30 PM
primordialbeast117
12-19-2015 12:23 PM
Ditch Doc
10-27-2015 03:20 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: Yota Techers I need your help
