why do they detune the 4runner's engine?
I was looking at toyota's website and the new 4runner engine they say makes 270 hp. But if you look at the Tundra / Sequia they are making 282hp.
I just don't understand why take the same engine and take it down to 270hp.
Just like with my '03 4runner they say it makes 235hp, but then they have the v6 engine making 245hp. I know that the v8 has a lot more torque then the v6, but it sort of pisses me off that the hp is lower. Does the new (vvt) on the v8 engine make that much difference to bring the hp up 35hp?
There are also sometimes reasons like the available transmission or axle needs protected. (So they think...) A good current example is the Cummins deisels in the pickups. That engine can produce a whale of a bunch more power, quite easily. People using after market computers (and even injectors and fuel pumps) to boost the power frequently find that when they pull their trailer they blow up the other drivetrain parts...
If Toyota is anything like Nissan then their just numbers and mean nothin, the 270hp V8 has the same rating as the Tundra and Sequoias with 282 but Toyota just puts down 270, we will only know if someone dynos the 2 vehicles and the numbers match.
Im willing to bet if their is an actual different then it's something small like a more restrictive exhaust.
Has anyone here ever compared the 190hp Tacoma to the 184hp 3rd Gen V6 4Runner, always wondered why the 4Runner did not just have 190 like the Taco or was it just lower numbers on paper
Chip in SC
Originally Posted by ipchay61
Seems like I read somewhere it was due to differences in the exhaust or muffler.
Chip in SC
Chip in SC
Originally Posted by SuperRunner98
I'd have to agree; all of the Tacomas and V6 Tundras I've heard have a deeper exhaust note than the 4Runners.
I think Toyota may be fudging the numbers on the 4Runner to make it look like it makes less power (Chev does this). If you look on Toyota's website, the new 4Runner can tow more than the Tundra's
2005 4Runner
Towing capacity [10] (lb.) (2WD/4WD)
V6 models (weight-carrying) 5000/5000
V8 models (weight-distributing) 7300/7000
2005 Tundra
Towing capacity [5] (lb.) (2WD/4WD)
V6 5000
V8 7100/6900
2005 Tundra Double Cab (lb.) (2WD/4WD)
V8 6800/6500
2005 Sequoia
Towing capacity [5] (lbs.) (2WD/4WD)
V8 6,500/6,200
2005 4Runner
2005 Tundra
V6 5000
V8 7100/6900
V8 6800/6500
2005 Sequoia
V8 6,500/6,200
2005 4Runner
2005 Tundra
V6 5000
V8 7100/6900
V8 6800/6500
2005 Sequoia
V8 6,500/6,200
2005 4Runner
2005 Tundra
V6 5000
V8 7100/6900
V8 6800/6500
2005 Sequoia
V8 6,500/6,200
Jnkml
07-06-2015 01:20 PM
