When the time comes 3.4to 3.4
When the time comes 250k the 4Runner will need a new mill. I know I have asked before, but this time I already know what I do and don?t want to do. I want to just straight swap my old 3.4 for a new 3.4. I will not be adding a SC but will be adding headers and exhaust. I don?t want a SC simply because of the reliability issue. Yes, I know there are quite a few of you that would tell me you don?t have issues with yours. But I ask you do you put btwn 30k-50k a year on your vehicle to really know what reliability issues lie ahead. My question is from where should this new mill come from? I know if it?s a junk yard I want the same year range 99-02 so I can eliminate problems or differences btwn years.
Aaron
Aaron
Aaron
Aaron
Just my $.02.
There are probably reman places to get them, or junkyards, or you could buy a salvage from a rollover or something like that.
If you're just going stock, why not rebuild the engine you have? Is it a downtime issue? From my experience with high mileage Toyota engines, they show very light wear on the more expensive parts ie: pistons, cylinder walls, crank, etc. This means you can generally expect to get away with replacing rings, bearings, gaskets for the most part. As long as everything is in tolerence when you put it together you have no reason to not expect another 200k out of your engine. A quick Google search turned up RPM which shows an Engine Kit for $544 and a Master Kit for $835. So my guess is without major machining you could probably complete a rebuild for about $1500 or so, maybe even less.
On the SC note it will add btwn $4K and $5k to have it properly done. I have shopped this one extensively. I would love a SC but the addition in cost isn't worth it. Maybe I'm missing something. I would need SC, fuel mods, or URD kit + labor and install then a magician to tune it.
On the swap not I didn't consider a rebuild or rebuilding my own that might be a more affordable way to go. The down time is an issue currently like if I did the swap tomorrow I have a work truck so no biggie. By then who knows hopefully be driving my cool cruiser restored unit around (oh to dream). I know I want to keep the rig and I drive alot.......alot......alot.... so I figure better to just straight swap out when its time. I was talking to a guy about the 1ufz or fz swap and that would have been an idea but no one is any further on making it easy sooo no go. If this was a trail truck I would love to stay toyota with it but I'd just drop in a 5.7 chevy, or a 4cyl TD. But back on topic 3.4 to 3.4 for sure headers and exhaust unless that has already happened to the current mill.
Aaron
Aaron
If you're after reliability I'd stay with the stock exhaust manifold. The newer tubular style 5vz exhaust manifolds seem to work pretty good to me. Now the 4 cylinder manifolds are a different story.
Aaron
Aaron
James
Man, if I still have my rig at 250k and my engines goes, I'm swapping in a 1GR-FE. 3.4L is a great engine. But whenever I ride in my friend's 05 4Runner, I do get the envy of the extra power.
But like others have said, no need for a new swap. Just rebuild. If you really need to, I'm sure you can just go to a junkyard or there will be plenty of online sources available at that time.
BTW, I'm at about 35-40k miles per year, too.
As far as finding a used 5VZ, mine came from a low mileage wreck. I'd trust a salvage engine more than a rebuilt one, unless I did the rebuild myself.
Aaron
Guest
the 1uz 4.0L lexus v8 should fit nicely, thats what i plan to swap when i grenade the engine or transmission in mine. there was a former staff member doing the swap to his 2nd gen, he shall remain nameless.
I know C to the e by but he cautioned me against such a swap because they still have no got all the kinks worked out and the adapters are still difficult to come by because each are 1 offs of the last. I know it will weigh about the same which is good and the power range is a nice addition but still for the reliability issue you can't beat the stock wiring looms. I wanted to believe me but no go on reliability. Actually there is a 1-UZ forum where there talk about this.
Aaron
Aaron
