Wheel spacers questions, pic inside...
Until I get alittle more money, can I run these spacers to make my wheels stick out farther. I am currently lifted 2.5 inches, but dont have the money to buy new wheels which have a better offset to fil the fender flares. So could I run 2 of these 1/4 spacers on each corner to fill the fender flares a bit more, just until I have the money to buy new wheels and tires? Or I also have the option of buying 1/4" TO 3/4" THICK HUB CENTRIC FLAT SPACERS for $40 EACH from this guy who custom makes them to a vehicles specs, but they are also a bit costly? What would you do?
How much space can I add before I need new lug bolts?
Thanks
Tim
Here's the spacer, just a generic spacer:
Thanks
Tim
Go to www.protrux.net
They have 1/2 inch spacers I believe. That would be much better than 2 1/4 inch spacers. I think they are 150.00 a pair. So if 300.00 is worth it to you to fill that amount of time....then go for it.
I think it is pretty crucial to get the spacers aligned right...or you might get wheel vibration or uneven wear. I think installation is alittle more complex than simply bolting on.
The ones Hyperlite posted are the way to go. I know several people that have had them on for years, and they still don't have any problems, even after dozens of trips hauling ass and jumping in the desert.
Originally Posted by Hyperlite
I'm running 2" spacer from StageWest4x4.com. Call em and they will make whatever size you want. I did pay $320 for all four though. I rather be wider than rollin over when I take a sports-car-corner in my truck with about 5" of lift anyday. But like Turboale said, I'd save my money and buy new aluminum wheels and get the spacers then.
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
