What size Rims for 32x11.5 R15
Old 10-31-2005, 08:17 AM
hill's Avatar
Ive heard rumor that stock rims from a 2nd Gen (7" R15) are too small for 32x11.5 tires.
What is a better size? 8"? 7.5? 9?
Cheers
hill is offline
Old 10-31-2005, 08:25 AM
westy44runner's Avatar
I have 32x11.5 BFG Muds on stock 7" 4runner rims and they are fine. You will not have any problems...
westy44runner is offline
Old 10-31-2005, 08:46 AM
Racer944's Avatar
it's recommended that you stay within 4 inches of the tire width, so the prefered methodis to upgrade to 8 inch wide rims, however, as westy is stating from experience, it will still work with stock 7's
Racer944 is offline
Old 10-31-2005, 08:54 AM
ToyoRunner94's Avatar
7" stockers will work just fine. i run 33x12.5 on 8" rims. going up one size from 31's wont pose that much of a threat. save your cash for something else, tear up those stockers first.
ToyoRunner94 is offline
Old 10-31-2005, 09:10 AM
Cebby's Avatar
I ran the stock 7" alloys for two sets of 32 x 11 BFG AT's. Make sure you rotate routinely. Mine had a tendency to get some odd wear on the outside of the front tires - although this was due in a big part to a bad alignment or two.
Cebby is offline
Old 11-02-2005, 05:48 AM
hill's Avatar
thanks, i was worried about having to go to black steel wheels....PHEW...ha ha ha...
maybe ill invest in a good alignment.
and god dam i gotta find a welder to tack up these sliders.
hill is offline
Old 11-02-2005, 06:22 AM
Senior Member
jacksonpt's Avatar
I ran 32/12.5-15s on stock 7" rims for a long time (about 45k miles, on road and off) with no problems.
jacksonpt is offline
Old 11-02-2005, 07:23 AM
4Crawler's Avatar
Shold be no problem on 7" rims, although you may have to shop around for a tire shop to mount them. I run 33x10.50s on my stock 6" rims (same width difference) and they work great, air down nice off-road and aired up the are decent on the road. You have to work on finding a good pressure to run on the road.
4Crawler is offline
Old 11-15-2005, 05:51 PM
calg3's Avatar
I have run my 32" BFG AT's for many miles on my stock 15x7 rims at 25 psi with no problems.
calg3 is offline
Old 09-10-2009, 03:33 PM
Slowrunnin's Avatar
I have 32x11.50xR15 on my 92 stock rims with no problems!
Slowrunnin is offline
Old 09-10-2009, 07:41 PM
B. Graves's Avatar
can you run a 10" wide wheel with 32x11.50s without problems?
B. Graves is offline
smilen724
13
11-08-2015 04:11 PM
Cycles
09-29-2015 06:37 AM
oldblue
09-28-2015 04:07 PM
gp66
09-14-2015 12:10 AM
Gravel Maker
RuffStuff
09-08-2015 05:46 AM
Quick Reply: What size Rims for 32x11.5 R15
