Valve Cover Gaskets
Old 08-29-2011, 04:11 PM
FORANA's Avatar
Valve Cover Gaskets
My 97 runner's valve cover gaskets seem to be leaking. I wasn't going to have it fixed because I was planning to sell it soon. But now it looks like I'll have to drive it for 2 more years. Was going to buy a 2012 tacoma but with the details slowly coming out, looks like I'll have to wait for the 2014 tacoma.
2 questions for you all
1. should I fix it at all or just leave it? Not dropping too much oil but I do get a few drips where I park.
2. How much would I expect to pay to have it fixed? No way I can do it myself. I had a mechanic friend say ~$400.
What you guys think?
Old 08-29-2011, 04:47 PM
MaK92-4RnR's Avatar
They're about 3-400 bucks to have a mechanic do it. I left mine alone but then my truck blew the headgasket and it was pretty much given at that point.
Old 08-29-2011, 05:56 PM
bamacj5's Avatar
Holy Crap 400 dollars, looks like all those years of automotive school paid off.
Lets see 2.7 hours flat rate for the job, and you can get a set of Fel-Pro gaskets at advance auto parts for 32.99
average independent shop rate $70 to $80 an hour, you do the math
and aliitle oil on the ground is alot of oil on the exaust manifold
its realy not that bad of a job and you wanna make sure and do the rear cam plugs while your at it
Old 08-29-2011, 06:46 PM
Kerby J's Avatar
for $400 you could buy all the parts (from the stealership ) and all the tools need and still have plenty of money left over for beer
Old 08-29-2011, 06:58 PM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
before you go replacing them completely, try tightening the bolts down (not too much, as it's aluminum!). when i just replaced my plugs and wires a couple weeks ago, the bolts were loose! it's a common problem that can be shored up, until you do the time-intensive replacement where you have to remove the plenum, intake, blah blah 3-day-weekend...
Old 08-29-2011, 07:11 PM
Pat in Wa's Avatar
I thought this was going to be a hard task to complete on my 1999 4runner but it was actually fairly easy took me about 3 hours to do. hardest part was moving the stupid electrical wiring harness out of the way. Be sure not to over tighten the valve cover bolts. I paid about $50.00 for the fel-pro gasket set at Orielly auto.
Old 08-30-2011, 11:49 AM
FORANA's Avatar
Thanks guys. There's no way I'm going to do it myself. So I guess what I'm asking is should I just leave it alone if I'm going to sell it in 2 years?
If I do fix it, what's a reasonable price to pay a mechanic? I know its cheaper if I did it myself but that's not happening.
Old 08-30-2011, 01:19 PM
4x4climber's Avatar
Did you try the tighten the bolts recommendation?
If your "friend mechanic" is gonna charge $400... find new friends... My good friend rate... 30 pack and some pizza, you bring the parts. or $100 and i will go pick up the parts and pizza/ drinks.
If it was a 22re... I would only require a 12pack. Wouldn't even be able to finish a beer before i would be done.
Old 08-30-2011, 01:30 PM
badattitude's Avatar
No, you can't wait two years if it is leaking. Oil can also get into your spark plugs if the gaskets is leaking. Maybe pull a couple plugs and take a look. But the short answer is you'll have to get it done.
It is a good idea to check the valve cover bolts as mentioned. They are lightly tourqued from the factory and to come loose over time. perhaps you just need to tightent them a little
GL
Old 09-03-2011, 09:31 PM
FORANA's Avatar
So I tightened the bolts today, they were all pretty loose. I could only access the 4 bolts on the lower parts of the valve covers. Is there an easy way to access the 4 on top without pulling everything off?
Old 09-04-2011, 07:49 AM
sdsurfer's Avatar
Can you tell us more about the rear cam plug? I just did one side and I didn't remove plugs. I just added a new bead of gasket seal, new gasket and torqued to spec. I cleaned the surface thoroughly of course.
Old 09-04-2011, 07:51 AM
sdsurfer's Avatar
See YouTube. Valve cover gasket 4runner. Sone guy and a 14 min video breaks it down. Good luck
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
irritech
07-27-2015 05:15 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: Valve Cover Gaskets
