Turn signal switch ...
hope this helps... should have all u need and then some....
http://www.ncttora.com/fsm/1996/SIL/index.html
Team420,
Thanks for the online manual links, am sure I am going to be using them in the future. Went through both and unfortunately, neither details how to remove the turn signal switch. May just have to mess with it ...
I had to change mine too, was pretty straightforward. You only need to remove the plastic around the steering column, the screws are on the underside, and the switch assembly was held in with 2 screws I think (been a few years so I don't recall exactly). You def don't need to sweat going at it without a manual or guide.
Manual
icentropy
07-14-2015 10:23 AM
