Tundra Brake Upgrade part/advise needed.
Old 09-23-2007, 09:45 PM
Fingers's Avatar
Hope someone can help... I upgraded my brakes last year to 2003 Tundra calipers (231mm) and I bent to destruction one of the piano wire brake-pad tension anti-rattle doohickies, so I did without it on that side. After a year of noise I finally can't stand it anymore and want to fix the problem I caused. Does anyone know where I can buy the wire "thing" without buying a set of pads? Or does anyone have a alternative way to prevent the dreadful rattle of the pads? Help appreciated. Unfortunatly I can't go to a dealer because I am in Japan and 1) Tundra is not sold here 2) Getting the parts guy to understand I have Tundra brakes on a 4-runner (HILUX) would be a translation nightmare.
Old 09-24-2007, 06:53 AM
Ian Rogers's Avatar
What if we could get the toyota part number and then you could go to the dealer would that work?
Old 09-24-2007, 04:25 PM
Fingers's Avatar
That would be perfect. Is there a place on-line where one can see part numbers for Tundra brakes?
Old 09-24-2007, 04:56 PM
Bighead's Avatar
Not the part number but if you enter one you could verify it is what you need: Toyota of Dallas
Old 09-24-2007, 07:08 PM
Ian Rogers's Avatar
what about tundra solutions .com
Old 09-24-2007, 09:24 PM
sdstud212001's Avatar
picture?
Old 09-24-2007, 11:09 PM
86tuning's Avatar
What about phoning your local dealership and buying a hardware/fitting kit which will include all that stuff?
If they don't keep it in stock, they can get it for the next day.
Old 09-25-2007, 01:56 AM
kevin444's Avatar
if your talking about the wire thing that looks like a "W"
i happen to bought mine a couple days ago
the part number for that for my 231mm set up is:
04967-0c010
Old 09-25-2007, 04:40 AM
Fingers's Avatar
Yes that is what it looks like. Thanks I'll try to use that number, but it did not work in the Toyota of Dallas link above. How did you get the number? BTW what made you go with 231mm vice the 199mm, and did you have to mod your wheels?
Old 09-25-2007, 09:25 AM
kevin444's Avatar
i like to go all out on my mods. Im running 17" tundra wheels
Old 09-25-2007, 10:33 AM
I went half way but all toyota 17" 06 4runner wheels
Old 09-25-2007, 11:47 AM
kevin444's Avatar
If that part number doesn't work.
This is what the little zip loc baggie said. on the label.
Description: Fitting Kit, DISC Brake FR
Come with 2, i'm pretty sure you only need one per side, But they're are sold in pairs.
correction: i made a typo on the part number sorry.
04947-0C010
those are all zero's by the way no "ohs" hahaha
Old 09-25-2007, 03:43 PM
Fingers's Avatar
That's it, the number works, $2.28 is all. Hope it will work at the japanese dealer, but if it doesn't I can mail order from ToD. Very much appreciate the help.
Old 09-25-2007, 05:40 PM
kevin444's Avatar
not a thing, when u get them could post a pic on the thread with them installed i kinda forgot how to put them back in hahah.
But yeah your welcome, im fed up with people with there freaking deckplate and exhuast questions
Old 09-29-2007, 04:35 AM
MTL_4runner's Avatar
The caliper W-spring always gets installed at the top of the caliper.
Here's the right way to install them:
http://www.ultimateyota.com/index.ph...18407#msg18407
Old 09-30-2007, 02:38 AM
kevin444's Avatar
thank you.
Old 09-30-2007, 05:57 AM
thank you.
No prob Kevin.
Old 10-05-2007, 04:56 PM
kevin444's Avatar
For people using the 13WL 231MM Calipers. This is how you install the clips. You will need two per caliper.
Old 10-05-2007, 05:25 PM
monster900's Avatar
Are those the same as the FJ wheels?
If so do they fit ok on the 3rd gen 4runner and does that make it easier to do the big brake upgrade. I have a 96 limited that has warped front rotors and I want to add the FJ wheels when I do the brake upgrade.
Thanks.
06-01-2021 01:51 PM
94ofCanada
08-14-2015 06:37 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
konah
07-30-2015 02:08 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Tundra Brake Upgrade part/advise needed.
