Toytec top plate spacer. Do I need extended studs?
Old 03-23-2009, 06:17 PM
98srx6's Avatar
I am gathering parts for the trd/890 lift and am going to be using the toytec 1/4" top plate spacer. My question is, do I need to buy extended studs or will I be able to reuse?
If I do need the extended ones, where can I get them?
http://toyteclifts.com/index.php?pag...mart&Itemid=53
Old 03-23-2009, 07:14 PM
waskillywabbit's Avatar
You will need extended studs. Typically the top out spacer comes with the studs.
Scroll down some
http://www.wabfab.org/96024Runner/96...iftoptions.htm
Old 03-23-2009, 07:32 PM
rocket's Avatar
The studs Sonoran Steel sold where made by Honda. I have the part number somewhere but you can call or email Steve and ask him for it.
http://i2.photobucket.com/albums/y30/-ice/AK-47002.jpg
Old 03-24-2009, 03:17 AM
98srx6's Avatar
I already have the spacers and I only need the studs.
Steve doesn't remember the part number that he used and also doesn't recommend the top out spacer anymore.
Old 03-24-2009, 06:01 PM
98srx6's Avatar
Does anybody know where I can buy some of these extended length studs or does anybody have a part number or manufacturer? Thanks in advance.
Old 03-25-2009, 12:24 AM
rocket's Avatar
That's ironic in so many ways.
Thought I had the part number but only know they are 38mm genuine Honda studs. Try taking one of your old studs to a Honda dealership and see if they can compare...it's a common part so should be easy to figure out.
Also call Toytec..they currently sell the studs in a separate parts-package.
Old 03-25-2009, 02:43 AM
KZN185W's Avatar
I think the studs are available from wheelers off-road:
http://www.wheelersoffroad.com/9504revtektaco.htm
Old 03-25-2009, 06:37 AM
sschaefer3's Avatar
That's not really what Steve said............
Old 03-25-2009, 08:36 PM
Gerdo's Avatar
I am told that you don't need extended studs with the 1/4" TO Spacer. Call Doug at ToyTec and ask him, it's his spacer.
Old 03-25-2009, 09:55 PM
98srx6's Avatar
Sorry, I guess my earlier post wasn't an exact quote, but it was close. I wasn't trying to take a shot at you with that comment Steve, you have helped many on this forum including myself and it is appreciated.
Thank you all for your help with this matter.
jasonty
41
12-23-2018 01:00 PM
4Runnin2000
07-29-2015 06:09 PM
TDonkey
07-26-2015 10:14 AM
whereAreMyPants
07-22-2015 03:32 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Toytec top plate spacer. Do I need extended studs?
