torsion lowered
torsion lowered
Are there any consequences to lowering the torsion springs?
I got under my 4runner and noticed the bolts were tightened way up.
Anybody have a stock measurement from the top of a 15" tire rim to the bottom of the wheel well fender?
Torsion springs? Do you mean torsion bar? If you are speaking front then my measurement is approx. 13.75 in. I do have aftermarket rims on so It may be a bit different. Hope this helps.
That is close to where I was before I lifted to level out the front with the back after the Downey lift. Your truck probably sags like all 2nd gens do to some degree. Why not get the Downey HD springs or Performance Products springs? Downey also sells a 1.5" spacer you can put on top of your springs but I don't see the point since the springs give a little more lift but increase the load carrying without hurting the ride. They actually improved my ride substantially.
got a little confused. I though Cat-o-lean was at 14.25". I'm of the opinion that it is better to lift the back to level with the front than dropping the front. You lose ground clearance and my truck actually rides better now than it did before when it was lower.
Hawaiian 4R - is the back of your truck real high? Mine is slightly higher in the rear with about 14 5/8" in the front.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 07:10 AM
JookUpVandetti
09-30-2015 08:58 AM
Scotttekoch
09-28-2015 10:30 PM
