Tires question, searched but no answer found
I want bigger tire on my 94 toyota, i got 31 10.50s and they look cool but i would love to have that look of 33 12.50. Has anyone fit these on just a stock yota, I look under the front wells and there looks as if there is plety room for these tire. I mean the 333/12.50 are only 1/2" wider each way and an inch taller.
thanks in advacne
thanks in advacne
Discount Tire will actually put the tires on the rim and install to check for rubbing. I'm not sure what they'll charge if you decide not to buy them though.
On my Tacoma I've had only a few slight rubbing issues on the road going from 31s to 32s. When my suspension started sagging a bit I was rubbing anytime I stressed the suspension more than a speed bump. I'm back at stock until I can get a chance to put my lift in.
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
