tacoma stereo installation help
quick question...
I'm currently working on a tacoma stereo install and want to make sure i don't do something i regret...., what is the order of dis-assembly? I'm assuming after the bottom center console (with the 2 12V outlets) you can pull off the center bezel (that covers the AC/Stereo/Vents?) or am i missing something...?
i figured it out...for anyone else who is interested....
The front Stereo/AC/Vents bezel is attached in 3 places to the dashboard. The first location was described above, you'll have to remove the 2 x 12VAC cover panel and ashtray. behind the ashtray is the 1st screw...the 2nd and 3rd screw requires the removal of the AC/Fan bezel that can be removed once all the lever tips and knobs are removed, just stick a finger behind the bezel and pull out. Once the bezel is out, you'll notice 2 screws attaching the front bezel to the dashboard. After that, you're all set...
Regis
Regis
BeMiceElf
10-10-2015 09:40 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
