Which speed sensor?
I've just swapped in a tranny and tcase into my 02 Prerunner Tacoma from what I think was a 97 4runner (It was def a 4runner but have forgotten which year it was for sure...)
Edit: BTW, I've got the 3.4 V6 with the auto tranny.
Question is this: How do I figure out which VSS (speed sensor) to use since the 4runner tcase doesn't have one? (It has the spot, just has a cover bolted in it.)
At first, I thought just the same year Tacoma VSS as the 4runner tcase is from, but then after more reading, it sounds like the 96-97 4runners would take a mechanical style speed sensor in the tcase...
Here's some pics if it helps....
(Pic of my wiring connector)
So after making a thread on this on several sites, I didn't find any exact info on how to tell other than peak through the hole and count the teeth, which is a difficult task when the case is already on the truck... And which still didn't tell me whether or not mine took a mechanical one or an electric one, but in a few helpful threads, most seemed to think mine should take the electric one.
Soooo.... I made a crazy decision and just bought a random speed sensor on ebay. I found one marked as from a 98 4x4 4cyl A/T. It was marked as 11/32.
When I got it, first step was to see if it fit into the case--miraculously, it fit perfectly. Next step was to extend the wiring ~12 inches or so.
Once done and connected, I fired up the truck and took her for a spin and--Voila! I have a working speedo again!
Now just gotta figure out how close to actual speed it is getting me....
-Ferg
-Ferg
montanatruck
02-26-2017 07:07 AM
