Right front vibes when I let off the throttle?
Old 05-25-2010, 07:23 AM
CrunchyTaco's Avatar
I have a problem with my 99 Tacoma that has me baffled and without enough money to take it to a shop.
Little back info. It is a 4wd with All-Pro coilovers and UCA's in the front and their 3" leaves in the rear. I changed out my CV's about a month ago with autozone remans. I lowered the adjustable coilovers to 1.5" from 3" to help with the CV angle and hopefully decrease wear. I noticed on the passenger side the CV did not want to rotate at full droop. The driver side would without a problem. I went and got a new CV, same problem! At a greater angle the CV trys to make the ADD box rotate oblong instead of circular. I put it all back together and notcied I had no problem with the truck weight on it and it worked fine.
Fast forward to this weekend. My dad rolled his truck on the powerlines and I had to go back their in mine and help. My truck now has some extreme virbations any time I let off the throttle sharply. I can decel slowly and as long as I have a little throttle in then it won't do it. It shakes the truck pretty good.
I am not sure if my problem is related to the CV or not. I have been chasing a problem with the shakes for a couple months now to no real avail but this is much worse and I am getting afraid to drive it. I have went thru and checked most everything in the front end when I did my CV's. The UCA and LCA bushings were fine. I replaced the steering and sway bar bushings. The tie rods were good and have very few miles on them.
Any help would be greatly appreciated. I am supposed to take an hour and a half drive to a lake house this evening and I am kinda scared to drive it. I have no other way to get there and this will be my only chance to take a vacation til Christmas.
Joe
Old 05-25-2010, 07:39 AM
Swimmerboy2112's Avatar
Did you get an alignment and balancing after installing the coilovers and leaf springs?
Old 05-25-2010, 07:53 AM
Yes, an alignment was done after the lift install. That was a year and a half ago, it was fine until recently. It is not an alignment type issue. It is an extreme vibration/rapid up and down shaking, not a hum in the steering wheel.
kazuya2416
04-05-2024 02:17 AM
06-01-2021 01:51 PM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
rbh261
07-13-2015 12:04 PM
Quick Reply: Right front vibes when I let off the throttle?
