Regearing
Regearing
I am wanting to regear my 00 prerunner(v6 auto) and wanted to know from you guys if i go to 4.56 gears what it will basically harm and improve on my truck. i'm clueless with gearing. i'll be running 265/70/16. any help is appreciated.
trd,
most likely you have 4.10. on the little sticker inside your door jamb, there's a code on the sticker which identifies what you have. i can't remember all the details on which code it is, but if you search here for "gear ratio", theres a few threads that tell you which code to read and what it means.
or, call toyota's 800 number w/ your VIN and they'll tell you over the phone.
bob
bob
Originally Posted by trdeu4ia
the code says A340E
Originally Posted by Bob_98SR5
...but if you search here for "gear ratio", theres a few threads that tell you which code to read and what it means.
going to 4.56's from 4.10's is not that much of a jump, you will have slightly better acceleration, but will be turning higher freeway RPM than you would with 4.10's, so your gas mileage may go down, it will not affect the locker at all
Flying91
45
04-11-2024 04:39 PM
charlie_fong
09-27-2015 10:06 PM
Mike Maiato
08-28-2015 02:35 AM
