Rear Pinion Seal Replacement
Old 07-12-2005, 01:03 AM
TrevorR's Avatar
I've done some searches on this topic and can't find exactly the answer I am looking for. First should I be measuring the preload on the pinion bearing and setting it back to that point or should I just torque the pinion nut back down. If so how much torque, I keep seeing "about 200 lb/ft", but I would like to be a little more accurate. And second should I be replacing the pinion nut or just reuse the old one. Thanks for the responses.
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
Alaskan91
09-21-2015 04:39 AM
Jmiller1023
23
08-06-2015 07:03 PM
cchinny
06-25-2015 08:11 PM
Quick Reply: Rear Pinion Seal Replacement
