Question about truck beds for a '99 Tacoma Ext....
I recently hydroplaned and smashed the driver side part of my truck bed.
Question is... someone told me that truck beds also come in parts. Like the driver side/bed/passenger side are bolted together? Is this true? Cuz I might be able to get away with just replacing the side instead of replacing the whole bed... unless luck is with me and I find a truck bed cheap.
Any helped will be greatly apprieciated. Thx in advance.
Maybe you could find a used box that was hit on the passenger side that still has an intact driver's side. Buy/remove the whole box and drill out the spotwelds attaching the bedside to the bed. It's better to use an actual spotweld cutter bit instead of a regular drill bit.
Thx for the reply... now then... would I have to reweld the wall back? I can't weld Looks like I might have to take it in.
Yup, it's gotta be spot-welded back on. You could get an estimate of the job from a body shop, then compare the cost against replacing the whole box with either good used or new (or aftermarket?) to see which is cheapest.
Thx for your help... its apprieciated.
GreenLion
06-07-2021 10:49 AM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
