power window problem, GRRRRRRR
nothing works at all. even the back glass wont roll down. i got a new master switch and installed it and nothing. what are the common problems for the 3rd gen 4runners? (its not locked out btw)
First, don't rely on a visual check of fuses. Use a known good fuse or put a test light or meter to BOTH ends of the fuse. Check 30A POWER fuse and 10A ECU-IG fuse.
If no joy, try swapping POWER relay with another relay. Failing that, I can take you through some real troubleshooting but I need your year, model, engine. You list your mods but not your rig.
This may help:
This may help:
Window
There is 12 volts at about 4 terminals at the molded plug. There was a little green corrosion (copper in the upper left side of the plug, but not too bad)
This may help:
This may help:
Patience, grasshopper. See p. 24 of attached, top right corner of panel. That relay should interchange with several relays in the engine relay box, such as FOG, DEFOG, PWR OUTLET, etc. Also EFI, but don't use that one.
One more thing: I think people reading this thread should see this one: https://www.yotatech.com/forums/f2/9...please-132635/
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
