power steering help
Old 04-04-2004, 09:06 AM
notaco's Avatar
power steering help
I drive a 92 pickup with v6. In the past say 2 years I have replaced the power steering pump 3 times. Part of that time I drove without the pump on. Well the pump went out again. My question is, did driving without the pump mess up the gear box which is causing the pumps to fail? Also, I have found a used gear from an 88 pickup. Are all of the ifs style boxes the same or would I have to make the older one work on my truck? thanks
Old 04-04-2004, 03:33 PM
barkeywayne's Avatar
I don't have an answer to any of your questions but recently I lost a bearing on the belt idler pulley on one of my trucks and was forced to remove the power steering belt. I drove it that way for about a week and it didn't seem to have any negative affect on the ps system when I got it back together. Somebody around here ought to know this one. Good luck!
Old 04-04-2004, 06:51 PM
notaco's Avatar
yeah I was going to replace the gear box last time but when I put the new "junkyard" pump on it worked great. This pump lasted much longer than two pumps from the "zone". I am planning on putting a front locker in and am wondering how the it will last if I just do the pump again and not the gear.
Zpd426
01-02-2016 01:15 PM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: power steering help
