poor gas millage and gas smell, with a p0171 code
#43
Already did and it's running way better now and no CEL so far, drove it pretty good yesterday and no problems, I had to use jb weld to attach the little nozzle thing that sticks out for the line to go over, and idea what this part is and where to get it from? Besides a stealership?
#44
If i remember right that part just threads into the power steering pump. Could try an auto parts store but they may not sell it alone from the pump. Or if you found one at a wrecking yard
#46
Yea that's the part, I guess I'll try blue and gold, I've had pretty good luck withthem before , I just don't want a brittle old one that's gonna do the same thing laterddown the road, but I do need a new console so maybe that'sa good excuse ! Where are you you from 98?
#50
i fixed my mpg pronlem the other day just by reseting the ecu and now im getting like 25-26 in town
is there a trick to finding vacuum leaks or is it just looking very hard for the leak
#51
Dreidel...use a propane torch...unlit....turn on the gas..and point it at all vacuum line/gasket areas.....it will rev up from propane if there is a leak.
#52
ok cool thanks im just glad i fixed for the most part my mpg problem simply by resetting the ecu (kinda sucks because today i was offered to good o2 sensors off a camery but ill save them for later)
crammit442
7
11-29-2017 12:30 PM
