oil pan removal
oil pan removal
Is there an easier way to remove the oil pan on a 99 tacoma, 4 WD, 2.7 liter, TRD than to pull the engine? Crawling around under there provided no answers for me, either did the manual. I am asking because of thread i posted earlier about the oil pump problems I'm having. Diagnosing gives a pissible oil pick up tube issue, and it would be nice to be able to get to that without yanking the engine completely out again.
I was told to drop the front cross member...that would be the easiest...but it looks completely welded under there...doesn't look like anything with bolts could just be unbolted and "drop out."
09-04-2015 09:27 AM
