Noise coming from engine: timing chain?
Old 09-08-2005, 11:35 AM
Nolan's Avatar
Sometimes (about once every 2 weeks) when I start up my engine (only at start up) I get a weird noise that is coming from the front of the engine. It is very hard to describe but it almost sounds like a belt or chain is not seated properly. It is kind of a high pitched noise but it is not squealing like a belt. The engine does not seem to be running rough either; it just has this loud noise. I can either REV the engine to get the noise to go away, or shut it off and start it again and it will run just fine. I know I did not give a very good description but that is the best I can do. I will try and maybe get a sound clip if I can catch it.
What does it sound like when the timing chain guides are gone or when the chain needs to be replaced?
Old 09-08-2005, 08:41 PM
Elton's Avatar
sounds like a timing chain how many miles do u have on ur 4runner
Old 09-08-2005, 09:13 PM
kyle_22r's Avatar
if it's anything like the sound of a 22R timing chain headed south, it'll tick intermittently with light loads and really tick badly with a load on the engine.
Old 09-08-2005, 09:17 PM
jimbo74's Avatar
um... does his truck use a timing chain?!
Old 09-09-2005, 12:23 PM
Nolan's Avatar
It only has 130K on it.
It does have a tick but only when the truck is moving. If I rev the engine while stationary it does not tick. Also, the tick seems to be vehicle speed (MPH) related and not engine speed (RPM) related. Does that indicate timing chain?
I assumed the tick was coming from my driveshaft (becomes more frequent as vehicle speed is increased-indpependent of engine speed) which is another issue (being 2wd and lifted and not having a double cardigan driveshaft joint give vibes).
Yes, the 2.7L engine does have a timing chain.
Old 09-09-2005, 06:01 PM
kyle_22r's Avatar
then you can cross the engine off your list. i know this sounds dumb, but have you checked your tires for rocks stuck between the tread?
Old 09-10-2005, 12:22 PM
Brendan's Avatar
timing chain sounds like a marble being rattled around in a can
Old 09-10-2005, 08:41 PM
getitdone's Avatar
I hear those damn marbles pretty much every time I start the truck.
Old 09-10-2005, 09:31 PM
Elton's Avatar
i hear the same thing when i start my truck mine sounds like a diesel then it goes away
Old 09-11-2005, 09:10 AM
RuffRider's Avatar
That "diesel-like" sound often comes from low oil pressure...
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Noise coming from engine: timing chain?
