need advice on body lift install
Old 04-08-2005, 02:43 PM
2wheelBLACKOUT's Avatar
Question need advice on body lift install
sup yotatechers..i am going to order a 4crawler 2 inch body lift for my 3rd gen. i plan on doing the install my self with the help of some buddys. my question is. is this a difficult task to tackle?? i've read all of the 4 crawler instructions and they seem pretty easy and straight forward. but i just want some yotatech advice. are there any precautions/preparations i should look for b4 the install?? i do have experience with working on my 4R. i am mechanically inclined so no worrys there. its just that this will be my first body lift project and i want to tackle it with full knowledge and attention. any advice would be greatly appreciated. Oh yeah on a scale of 1-10 what would you rate a body lift install.??
Old 04-08-2005, 03:57 PM
Good Times's Avatar
work one side at a time.
Old 04-08-2005, 04:06 PM
Jared Ajlouny's Avatar
easiest lift ever, i did it on my for explorer with a kit that wasnt even made for it. it was also the fisrt time i ever did anyhting to a car besides changing the oil.
Old 04-08-2005, 04:38 PM
yote4x4's Avatar
its no problem at all..just take your time and don't rush anything. a solid installation now will save you time and money later on
Old 04-08-2005, 08:03 PM
anthony1's Avatar
I have instruction from Performance Acc. body lift.
It's easier than doing IFS lift.
http://www.angelfire.com/ca6/954runner/bodylift.html
Old 04-08-2005, 08:09 PM
rimpainter.com's Avatar
Hardest part for me was the steering shaft spacer for some reason.
Old 04-08-2005, 08:15 PM
ElmerFudd's Avatar
I just finished one and the only hard part for me was dealing with rust.. UGh i hate rust.
Old 04-09-2005, 05:24 AM
waskillywabbit's Avatar
4Crawler Offroad Body Lift Kit Installation
Old 04-09-2005, 08:29 AM
4Crawler's Avatar
Be sure to hit the ends of all the body mount bolts and the steering rag joint bolts and clamp with a good penetrating oil for a few times prior to starting, as noted in the instructions. Do this every day or two for a week or so to give the oil time to work. Seems that the most trouble folks run into is that one rusty bolt/nut someplace that takes as much, if not more time than the rest of the project.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: need advice on body lift install
