My Fogs are Dead
Old 08-08-2004, 03:39 PM
4RunnerFever's Avatar
My Fogs are Dead
I've got power to the switch and I can hear the relay clicking, but no lights. Just happened out of the blue. Both bulbs appear good and the harness is hooked together well. I'm bummed
Any ideas as the to the problem would be helpful.
Thanks folks!
Old 08-08-2004, 03:45 PM
Localmotion's Avatar
Thanks folks!
THe last time this happened to me my ground was bad. That could be it...but then again im not too sure. Also the wiring in the switch may be bad...that also happened to me. I hope you find whats wrong...best of luck
Matt
Old 08-08-2004, 04:08 PM
waskillywabbit's Avatar
Talking Sudden death
Sudden death usually means one of two things:
1) blew a fuse somewhere (don't forget ones that may be in-line as well as in a fuse box)
2) bad connection, usually a ground wire
If they are Hellas or aftermarket, check the connectors coming off the relay as they have a tendency to wiggle loose and then electrical tape them up to the relay so thye are sturdier.
Good luck!
Old 08-08-2004, 05:05 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Could be a relay too.
See this post by me.
I had to test a relay, and I found out it was bad.
Replaced it and all was bliss.
Chicken12
10-14-2015 03:54 PM
Obmi
10-04-2015 11:30 AM
zombie_barbarossa
10-02-2015 10:54 PM
89YodaRunner
09-30-2015 02:18 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: My Fogs are Dead
