more sway bar bushings
Old 02-01-2005, 07:24 PM
Localmotion's Avatar
i am looking for sway bar bushings for my 1996 4runner. Also i am looking for some poly shock bushings. i found theses http://www.truckperformance.com/prod...y+Bar+Bushings but do not know if they will fit. some people said they had trouble fitting them. what do you think
Matt
Old 02-01-2005, 11:40 PM
Bigkahuna808's Avatar
contact the guys over at wheelers off road. I bought my bushing kits from them for cheap. In fact I still have a extra set in my garage just incase
Old 02-02-2005, 04:02 AM
Ilovemountains's Avatar
I actually just took my polys out..
I bought my poly bushings at AutoZone, they had to order the kit for my sway bar which was a good deal but I ened up having to go back and buy a set of end links which came with poly bushings also! IF you can get your end links apart check there the entire ProThane kit was $16 and it included end link and bar-to-frame bushings. My passenger side link snapped when I went to take it apart. I actually just took my front sway bar off all together yesterday.....
Old 02-02-2005, 10:30 AM
Alin10123's Avatar
you can order from www.summitracing.com
Also read about sway bar bushings on www.gadgetonline.com
From Summitracing, you can just order the diameter of your sway bars and they will fit. Make sure you get the greaseable ones and the ones in black so they are imbedded with graphite, otherwise they will squeek.
The rears... well... the summit racing ones didn't fit mine... So...
Let us know what you find.
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
Obmi
10-04-2015 11:30 AM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: more sway bar bushings
