knock sensor wire
knock sensor wire
Hi guys I have got the annoying "PING" in my engine and after reading several posts think I will try the Knock sensor wire mod.I need to know the correct toyota part # for the Knock sensor wire.
The wire will be part of a harness and not an individual part that you can buy. And trust me, you don't want to spend that kind of money doing a "free" mod. Just be very careful when cutting the insulation to get to the shielding and you shuld be just fine. Use some heatshrink to keep moisture out of the solder joint.
Good luck!
G
Good luck!
G
montanatruck
02-26-2017 07:07 AM
Steven.m.paulk
07-24-2015 01:44 PM
88yodabasket
07-13-2015 01:32 PM
