keyless entry questions
Does anyone know where the factory keyless entry module is for a 99 4unner (not an alarm)? Also, is it possible to change from the the drivers door unlocking first to having all doors unlock at the same time?
hey man i found that in my '01 the module for mine was in the rear hatch go figure i know but the only way that i know of changing it from jus unlocking the drivers door first then the others is to put in an aftermarket alarm or keyless entry and i would still do an aftermarket alarm because it is worth it
***Edit - I can't read! Thought you were looking for a remote
Kerby is correct. It is in the rear hatch.
I don't know if you can change the system to unlock all doors with the first button press. It might be a setting in the body control module that could be set with a scan tool, but I'm not sure.
Maybe someone else can shed light on this.
Last edited by element; 04-20-2008 at 08:48 PM. Reason: fighting illiteracy one post at a time
jmyer72
08-20-2015 07:55 AM
TJWilly
07-31-2015 02:05 PM
