Its Falling off!!!
Old 01-17-2005, 01:59 PM
theone's Avatar
Its Falling off!!!
on my 95 4runner, the plastic parts at the end of my running boards are falling off, how do you guys fix this?
Old 01-17-2005, 02:09 PM
bike4miles's Avatar
I had to glue a plastic loop on the inside and use bailling wire to tighten mine up. That was fine but later I just took them off. Looks a lot bigger that way.
Old 01-17-2005, 02:11 PM
callmej75's Avatar
take the running boards off....i had the same problem and took em off and now it looks less of a grocery getter
Old 01-17-2005, 02:31 PM
NathanBERG's Avatar
Roger that! take them off it will look alot better!
However if you wish to keep them. I would try some JB weld.
Old 01-17-2005, 02:36 PM
Scofco's Avatar
Mine also started to fall off.
I solved the problem by throwing the running boards in the garbage.
Old 01-17-2005, 02:57 PM
Vtec_Killer's Avatar
Mine are cracking too. I guess that's why you guys 'upgraded' to sliders. Where to get those BTW?
Old 01-17-2005, 02:58 PM
Guest
Yoter's Avatar
take em off the fun way. head up to the local trail and find some rocks. then rub up against them and hear the sweet sound of the running board removal mod.
Old 01-17-2005, 03:32 PM
theone's Avatar
LMAO!!!
I cant take them off because of my bad back i would hve a hard time getting into car and the crap part is i dont even any type of lift, so besides the stock boards what did you guys replaced it with, if you even did
Old 01-17-2005, 05:04 PM
Dublin's Avatar
If you really have to leave them on, yuk. Then just use black automotive tek screws. They are black with a wide flat head and are self tapping. Re-screw them on the inside of the fender and screw one in at the spot where the cap overlaps the running board. It will look like they belong there and last a lot longer than the clips inside the running boards.
Old 01-17-2005, 05:39 PM
callmej75's Avatar
hey dublin how did u stuff those 33's under there with no lift? any rubbing?
Old 01-17-2005, 06:29 PM
Fink's Avatar
Just take em off, it looks so much better!
Fink
Old 01-17-2005, 07:06 PM
Guest
Yoter's Avatar
sorry bout your back. thats gotta suck. I took mine off and with 7 inches of lift its a pita climbing in esp on ice. i put sliders from stubbs on and still a climb but is nicer and looks sweet and fully functional.
Old 01-17-2005, 10:41 PM
bike4miles's Avatar
Smitty Built makes chrome and stainless tubular running boards that are very stylish. I actually considered buying some myself. Kinda spendy though, sepecially the stainless ones.
Old 01-18-2005, 05:17 PM
Dublin's Avatar
Callmej75, They fit fine. I just drive in a straight line all the time. Yah I know I need a lift, cant take a sharp turn on an incline. no problems on the street though. To make em fit you need a big hammer and a saw, you probably need to do some trimming even with a lift.
hiluxinargentina
09-30-2015 11:12 PM
carid
Vendor Advertising
09-10-2015 06:11 AM
seab1209
09-03-2015 05:41 PM
Dee Draper
08-23-2015 11:54 PM
Kluch8651
07-09-2015 10:39 AM
Quick Reply: Its Falling off!!!
