Info on oil filter relocation kits
Location: Far western Kentucky (transplanted from central PA)
Info wanted on oil filter relocation kits
Having to pull the front skid plate off my 3rd gen is a bigger PITA than it was on my 2nd gen and, even with extended oil change frequencies with synthetic, I'm still changing my oil filter almost every 2 months. I'm considering a relocation kit.
I've seen the Perma-Cool relocation kit in the P.P. catalog for $59.95.
- Are there better kits out there?
- Is that a decent price?
- Where is a good place to mount the filter?
- Did you change to a larger filter?
https://www.yotatech.com/~corey/tech...msoil/tbob.htm
this is something close to give you guys some ideas, also try the search button I know theres some others on here
heres what i did:
http://www.4runners.org/articles/permacool
guys, you really need to search. there is a lot of info you can find by just using the same words in your questions
bob
bob
Thanks, guys. Are the Perma-Cool kit's hoses long enough to mount at a suitable place in the 3.4L 3rd gen or sould I assume I'll be modifying it with longer hoses? The add in the P.P. catalog states that it adds almost a quart to your oil capacity. Since it doesn't come with a filter, I assume thats the oil volume in the additional hose supplied with the kit.
I didn't want to mess with the PP kit so I just ordered the spin on adapter and filter relocation part that are used in the PP kit, and used my own fittings and hoses. It was a hole lot cheaper than the PP kit.
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
3rd, 3rz, 4runner, cool, filter, generation, info, infots115yahooin, kit, oil, perma, relocating, relocation, tacoma, ts115yahoin
