IAC vaive flow direction?
I know that this has been discussed before, but I am still a little confused about which way the flow goes. My valve did not come mark as illustrated in the manuel, so I took a guess that the flow goes from throttle body towards the manifolds- not the other way around. Am I right or wrong?
Thank you for your inputs.
TB to engine
You're right. It should open when air flows from the TB to the engine. Close when air comes from the engine. I had a similar issue, only I just didn't have the IAC check valve and picked up a PCV valve from Pep Boys. Works fine.
Zach
Zach
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
