I want to manually work the Torque converter lockup
How can I wire up a toggle switch that will cause the torque converter to stay locked up when it might otherwise unlock? This would allow me to tow more effecentily, and with less tranny heat by letting me choose locked OD or locked 3rd depending on my needs. I could also use it when driving for my work needs. Mostly cruiseing at 30mph to 35 mph. That would also prevent tranny heating. I am going to install a cooler and temp guage, but I thought that this could give me an extra measure of saftey for the tranny that I have not ever flushed. I did just drain and add 2 gallons of tranny fluid. Last year I did a drain and refill with one gallon. I should be shot for my tranny neglect, but I now know better.
Yup. Go with the add-on cooler (bigger = better, surface area is what you want to dissipate the heat!), etc. Personally I'd let the tranny do it's job and just supplement it externally where possible. Toyota engineers are clever folk, they make good parts. It's when we go mucking with them that they break in strange new ways.
Manually locking the torque converter is a pretty cool idea. However, I agree with what's been stated above - letting the truck operate how it was designed to is probably a good idea. I know you can keep 3rd locked by turning off the O/D button. When I want to pick up speed quicky on the highway I let it downshift into 3rd wait till it hits about 55-60 mph then turn O/D off, locking the torque converter - you will see the rpm's drop by about 500, then at about 70mph I'll turn O/D back on and let er' go from there. This is a very effective method IMO.
You know, I always wondered why the RPM drop happened with the O/D off. Cool! Though I seemed to get more power with it on, probably related more to engine powerband than the tranny - but I sold the Tundra and got a 5spd 4runner, so it's irrelevant now...
Jnkml
07-06-2015 01:20 PM
Suprarossa
07-06-2015 05:21 AM
