I got the Bilsteins installed but....
Old 01-23-2005, 03:17 PM
black_taco's Avatar
Hey guys
Me and a buddy intalled all new bilstein shocks this weekend on my 1996 tacoma, the job went pretty good but now it sits about an inch higher on the front driver side. I know that shocks aren't supposed to support the weight of the vehicle so it has me concerned. I was wondering why this is or what we could have done wrong? I was also wondering if the shocks or even the coil springs had to be in an exact location (sticker towards the front or anything bizzare like that) for everything to work right? Hopefully this is all the info you need, and thanks in advance for any help guys.
Old 01-23-2005, 03:21 PM
Tacotex's Avatar
I believe the rears are right/left specific. That could be your problem. Check the part # on the rears and make sure they are installed correctly.
Old 01-23-2005, 03:26 PM
Tacotex's Avatar
Just checked the #s on the invoice for my Bilstein HDs, and the rears are B46-2285 and B46-2286. You've either got two lefts, two rights, or have them reversed. The bilstein sight can tell you which is which.
Old 01-23-2005, 03:30 PM
TACOMANATOR's Avatar
He says it sits an inch higher on the front driver side. If you install the lower spring perch the wrong way it will cause this problem. I know there have been a few posts about it.
Old 01-23-2005, 03:33 PM
User 051420's Avatar
The coil cup on the drivers side is installed upside-down. Flip it, then reinstall.
Old 01-23-2005, 07:19 PM
black_taco's Avatar
Your right.....
It was the aluminum plate installed upside down. Thanks guys
Old 01-24-2005, 03:51 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Bingo. Same thing happened to me and to quite a few on the forum.
nvdesertrunner
05-11-2020 08:18 PM
punks_is_4x4
08-21-2015 01:35 PM
mr_manny
07-31-2015 10:39 AM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: I got the Bilsteins installed but....
