Old 04-12-2016, 07:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Cooling System Guides
Print Wikipost
how do you replace thermostat in 93 V6 4runner?
Old 02-23-2004, 07:09 PM
puffy's Avatar
I am going to try and do that. Is there a writeup on that somewhere on the net or can someone help me do that. I saw the one for 3rd gen with supercharger but I don't have neither of those so I am assuming its easier.
Old 02-23-2004, 07:51 PM
kev93p-up's Avatar
The first thing you need to do is go down to your local auto parts store and buy yourself a manual for your runner. The t-stat is extremely easy to replace. There will be a step-by-step in the manual.
Old 02-24-2004, 04:43 AM
CTB
CTB's Avatar
Like already said, it is really easy to do, just can be a little messy with all the coolant that will drain out.
A lot of vehicle thermostats that I have replaced have been at the top radiator hose, but on the 3.0L's, it is where the bottom radiator hose meets the engine block. Drain the radiator, unclamp the bottom radiator house from the thermostat housing, unbolt the thermostat housing, remove the thermostat (pay attention to which way it is oriented), and then reverse the process. Make sure your new thermostat (get an original Toyota one) has the black gasket on it before you install it. Pretty darn easy.
Then, refill with coolant, check for air pockets, and drive that thing.
Old 10-30-2009, 02:08 AM
ledfootfam's Avatar
There is one important part your missing. You must install the thermostat with the jiggle valve at 12 o'clock high. It will be a small valve somewhere on the rim of the thermostat on the side facing you. Slowly run the bolts in while adjusting if you need to sometimes this can be tricky. As stated before you must have a new gasket and properly clean the mounting surface before install. Also tighten bolts to 10-14 ft. lbs. Overtightening will break the ear off the housing and spoil your afternoon - Don't do it. Hope this helps.
Brandon
Old 10-30-2009, 04:12 AM
Team420's Avatar
Heres the link to that page in the fsm.....
http://www.ncttora.com/fsm/1990-1995...s/thermost.pdf
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
ZGjethro
06-07-2017 11:04 PM
Rcbc92
09-26-2015 03:00 PM
noahstancik
09-10-2015 10:47 AM
Quick Reply: how do you replace thermostat in 93 V6 4runner?
