How do you lower the spare tire after a body lift?
Well, the access hole to the spare tire mechanism is now misaligned. Hope I don't get a flat anytime soon.
I over looked this small detail after installing a 1" body lift last weekend. Has anyone else addressed this problem?
May have to remove rear bumper and never put it under there again or else climb under and turn it with a wrench or something. Not very practical if its raining!
suggestion. Drill a new access hole in the bumper if possible and install a chrome plug to hide the hole . You can buy plugs for this purpose at industrial supply stores. They are called (hole button plugs). Need to use the spare. pull out the plug.
The short answer is use a 3/8" ratchet with a 3" extension and reach under the bumper and stick the extension in the "horn" thingy. You can then lower or raise the tire with the ratchet. Better answer is relocate your spare (rack, bumper, etc.)
I'm going to do what Wild Bill suggested and try to get it down with the 3/8 ratchet and extension. Then I will be able to see the mechanism better and drill a new hole in the bumper or something.
I think Cebby is on to something though:beaver:
I was able to lower the tire using a 3/8" drive ratchet with a 4" extension. Thanks Wild Bill. I didn't think I was going to be able to swing the ratchet with the limited room above the tire, but there was just enough space.
With the tire out of the way I was able to fix the problem. I bent the hoist mechanism towards the rear of the truck to slightly raise the "horn" shaped reciever (it really didn't move much). Then I used a hacksaw to enlarge the existing hole in the body to allow the crank bar to tilt down and align with the reciever horn thingy. I cleaned it up with a file, painted it and it works perfect.
Here are some pictures:
Pic 1
Pic 2
Pic 1
Pic 2
You need to log yourself out of webshots before copying the URL..It thinks we are trying to log in as you (doesn't work for us, probably works for you though)
Re: How do you lower the spare tire after a body lift?
If your lift didn't come with bumper adapters, you may want to make some.
Re: Re: How do you lower the spare tire after a body lift?
Originally posted by upndair
The little detail that you missed, is that you should have a few brackets to lift the bumper up so that it stays aligned with the body. If you properly lift the bumper, you won't have the problem.
Steve
Now I'm
