How do I Produce ABS Blink Codes
Old 08-07-2008, 10:06 AM
tacotacoNewf's Avatar
I've got an 03 Taco 4x4 Extended Cab, 3.4L .. Recently the ABS Light came on for no apparent reason
i've been reading from so many places about getting the blink codes from your ABS Light, but Have dug and dug, and can't seem to find out any instructions on how to actually do this other than read the Chilton Manual.. which I don't have on me..
Wondering if anyone has any instructions on what to do to produce the ABS blink codes on an 03 Taco, and what to reference the # of blinks to...
Old 08-07-2008, 10:27 AM
Joe's Toy's Avatar
Hey TacoTacoNewf, the only ways I've read about getting the ABS light to blink is you jump two pins on a diagnostic port then you turn your ignition to ON and it's suppose to blink. Check out this link. Specifically post #5 and on. And read the attached pages from theToyota Service Manual. I've been looking for my diagnostics port to do the same thing your asking about. Read through that post and see if it helps.
p.s. Welcome to YotaTech!
Old 08-07-2008, 07:17 PM
BigBallsMcFalls's Avatar
yup. in this manual the SST is a hunk o wire
Old 09-08-2008, 05:34 PM
civilpd's Avatar
I have the 4runner one of those if you can tell me how you got the graphic onto the site I will post it. It is a little different.
Here is part of it...
2. In case of not using the hand-held tester:
ABS SENSOR SIGNAL CHECK (TEST MODE)
HINT:
If the ignition switch is turned from ON to ACC or LOCK during
the test mode, DTC will be erased.
(a) Procedures for the test mode:
(1) Turn the ignition switch OFF.
(2) Shift the shift lever to P range.
(3) Using SST, connect terminals Ts and E1 of DLC1.
SST 09843-18020
(4) Check that the steering wheel is in the straightahead
position.
(5) Turn the ignition switch ON.
PM me and I will try to get you the rest. I am having a problem also with my ABS.
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
Scotttekoch
09-28-2015 10:30 PM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Quick Reply: How do I Produce ABS Blink Codes
