Here's a thought (motor woes cont)
Ok.. here is one for you.. This may not be what is wrong, but I hope and pray it is..
I dropped off my 4Runner off last night, and I talk to the guy, and he had a thought which takes a little to think through, but it is possiable.. He said that cam timing could do this.. If the cam is out of time the valves open at diffrent timeing than they should and there is too much room in the compression chamber to compress to a high PSI. Basicly before the piston has the stored cubic feet of air compressed fully the intake valve ehxaust valve open pushing the rest of the air out the exhaust (or intake??) Now he is not sure, and I am not sure and The timing was dead nuts on, and set with a light.. However, the belt was new, then R&I the next day a year ago.. Well I didn't want to get into the bottom half of the blet when I did the motor.. Could it have jumped time on a head?? It could of.. I just have never thought of this theroy in relation to having no compression (or very low compression) but it is possiable to happen... I should know by the end of the week..
Yes messed up cam timing can potentially produce those symptoms. Your best bet if you have bad compressions numbers is a leakdown test though. You would be able to determine if your problem is your HG, rings, or valves, and if it's not any of those it may be your cam timing.
