HELP! Having trouble with spark plugs
I bought OEM Toyota Denso spark plugs and spark plug wires from Wires4Cars. After I installed them I started my 4Runner up and their was a huge power loss. It had a rough idle where the entire engine shook and the exhaust sounded wierd. I did some research on the forum and eyeballed the gapping and reinstalled everything. That didn't work, so I reinstalled the old spark plugs and wires to see what happens. The result was the same as before. If anybody has any ideas or ways to help I would appreciate it.
Roy
Roy
Originally Posted by RSimon
I took one off and put one on. I did this all the way around. Does anyone have a diagram or pic of their engine?
Roy
Roy
I went out to O'Reilly Auto Parts and bought a Spark Plug Gap and Feeler Gauge Set. I'm about to check the gap on all of the plugs right now. I created a drawing of the firing pattern I have now. I don't know where to host the pic though?
Roy
Roy
1999 Toyota 4Runner SR5 with a V6
Your factory wires should be fine and I definitely wouldn't replace them unless you are using OEM! It sounds like a plug wire. The gaps wouldn't cause a problem like you are having.
Yoter - How would I check each wire for spark?
Calg3 - I don'r have a distributor, I have 3 spark plug wires and 3 coil packs. My truck was running great, I did the Seafoam treatment and then decided to change the spark plugs and wires.
I went to Autozone to have them read the check engine codes and they came up with codes:
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
So now I'm thinking maybe 2 of the coil packs are bad. Can someone please post a firing order? The one I got a Autozone says it's 1-2-3-4-5-6 and comes with a diagram as shown:
| 1 _____ 2 |
| 3 _____ 4 |
| 5 _____ 6 |
front of engine
| 1 _____ 2 |
| 3 _____ 4 |
| 5 _____ 6 |
front of engine
I agree there is something possibly wrong with the wire set (install or product itself). When you get them off you should check the resistance of the original wires and compare it to the new ones....this will be a good indicator of what problem you are looking at. I would suggest next time to only use OEM components (incl plug wires especially).
I seriously doubt that any of the coil packs are bad....
Did you unclip the connectors on them when you changed the plugs?
If you stretched any of the wires you might have broken a connection.
Also make sure if you did unclip them that they got clipped back in properly.
IF the firing order is 1-2-3-4-5-6, then 1-4 are on the same coil, 2-5 same coil, 3-6 same coil. On coil pack vehicles, the spark goes from the coil, to the spark plug, through the block, back through the companion spark plug, and returns to the coil. ( IE, it fires 2 spark plugs each time...one on compression and 1 on exhaust stroke)
the front right cyl is # 1
FRONT OF ENGINE
2...........1
4...........3
6...........5
FRONT OF ENGINE
2...........1
4...........3
6...........5
| 1 _____ 2 |
| 3 _____ 4 |
| 5 _____ 6 |
front of engine
| 1 _____ 2 |
| 3 _____ 4 |
| 5 _____ 6 |
front of engine
| 5 _____ 6 |
| 3 _____ 4 |
| 1 _____ 2 |
front of engine
That would explain your error codes and the running rough. The cylindar map I just listed is the way it is on the 3.0, so it might be different, but I doubt it.
Thanks everyone I got the problem fixed. Thanks to the helpful people at Toyota of Richardson giving me a diagram and answering my questions I was able to solve my problem. My spark plug wires got crossed which was easily fixed. Again thanks everyone for all of your help.
Roy
Roy
Roy
Roy
