Help!! Coolant is disappearing!
Old 06-23-2003, 07:08 AM
Bobful's Avatar
Hi everyone,
I am loosing coolant from my 93 Pickup (22RE) and I can't find any leaks. There is'nt a drop under the truck. There is also no foaming substance in the crank case nor do I have the white smoke sydrome. Now here is the worst part: The coolant is rust colored. I have flushed it twice in the last month and it keeps turning rust colored. The truck runs warm as soon as the level of coolant drops in the radiator (after it sucks the overfill tank dry).
Anyone have this same problem? I would like to have a few ideas on what might be wrong before I take it in to be looked at by a mechanic.
Should I still be driving it? Any advice, help, wisdom, or warning would be greatly appreciated.
Thanks,
Robert
Old 06-23-2003, 08:08 AM
My 3.0v6 did the same thing. I topped it off and put some Alumaseal in there, and it's holding now. I figure it is the head gasket, but it's so slow as to not spew steam out the exhaust.
Keep an eye on all your fluids, oil, antifreeze especially. You can change the head gasket if ya want, it's alot cheaper than on my v6!
Old 06-23-2003, 09:09 AM
PY
Torque the head bolts in sequence. I've seen loose head bolts on high mileage engines, although not Toys.
Can't hurt, and it might fix it.
Old 06-23-2003, 01:27 PM
Amir904's Avatar
if u put that radiator sealant crap in there, it eventually turns that rust color. only reason i can come up wit the losing coolant syndrome is that blown head gasket, but then, you would have white smoke out of ur exhaust too, which u dont. so i dono.
Old 06-23-2003, 01:31 PM
Los Gatos?'s Avatar
Sound like a blown headgasket to me... the no white smoke part is odd...but the coolant has to be going somewhere. Check your oil for milkshake-y goodness.
Old 06-23-2003, 02:29 PM
Mack's Avatar
You may have a pin hole in a heater or radiator hose
Old 06-23-2003, 05:03 PM
92 Toyota's Avatar
Had the same problem with my 92 22re.I ended up with a crack in the head.water was leaking into the cylinder and getting burned off-no water in oil,no white smoke out exhaust.Take out spark plugs & look to see if any are really clean looking. If one looks really clean that's where your problem is.(mine was #3 cylinder)you can also do a pressure check on radiator with spark plugs out and if this is your problem you should see water coming out of spark plug hole.I drove mine for a month like this just kept adding water.(it was using about a quart every 25 miles.):pat:
Old 06-24-2003, 05:25 AM
Bobful's Avatar
Thanks everyone,
I will check the spark plugs and see if any come up clean. My oil looks good, there is no milk shake action going on. I fear though, it will be the head gasket.
I will also tighten the valve cover bolts. The other day I tightened one by hand, so that might be part of the problem.
Maybe I wil be lucky and it is just a pinhole somewhere!!
Thanks,
Robert
ladybugRC
458
08-21-2020 10:41 AM
alexcarey
10-14-2015 06:05 PM
kcaudill
10-10-2015 02:39 PM
dzldust
7
10-06-2015 05:39 AM
puddlepirate
09-29-2015 08:02 PM
Quick Reply: Help!! Coolant is disappearing!
