Grease gun
Old 07-15-2004, 12:11 PM
92foreruner's Avatar
Unhappy Grease gun
I'm wondering if anyone knows the size of the grease gun end I need to lube my driveshafts and the rest
Old 07-15-2004, 12:38 PM
Tacoma Dude's Avatar
I didn't realized there was a designated size - I thought you could just slop that stuff on
Old 07-15-2004, 12:42 PM
ElwayLite's Avatar
Its the standard size, i just bought one from home depot with the flexible end, works great.
Old 07-15-2004, 12:54 PM
Citykid's Avatar
I just bought two. I can't seem to get the tips screwed all the way on the hose though.
Old 07-15-2004, 02:19 PM
TechWrench's Avatar
Most grease fittings are equiped with a 'zerk' fitting. It looks like a small metal nipple. The size of the grease gun doesn't matter, what is needed is a female fitting on the end of the hose on the gun that will snap onto the zerk fitting. They are pretty much standard. Once it is in place, a few pumps on the gun will force the new grease into the joint. Just make sure you read the manual to see what type of grease is recommended for your application.
Old 07-16-2004, 08:19 AM
I have the standard grease gun it the female end that doesn't seem to work I put it on the zerk fitting and pump and grease goes everywere but into the fitting. Now this is a grease gun I took form work that we use on the equipment there eg. excavators, backhoe and the sort I'm just wondering if I have the wrong end on the gun
Old 07-16-2004, 08:24 AM
Flamedx4's Avatar
Coupla things - when you snap the female end onto the zerk, does it stay on? If so, try to hold the gun tip straight to the nipple, if it gets too off to one side sometimes it doesn't force the grease in and instead goes all over. Happens to me all the time. Second, it could well be that you have a stuck zerk. You can remove it and snap it into the gun and squirt some grease through it to check it.
Old 07-16-2004, 12:36 PM
ElwayLite's Avatar
Yeah, all mine were stuck on my taco when I went to do em the first time, I just used a pocket knife and cleaned up around the ball and then they took grease fine.
Old 07-16-2004, 02:46 PM
TechWrench's Avatar
There is a small spring loaded ball in the end of the zerk fitting, and what happens quite often is the ball gets stuck in the opening (dirt or rust). Just get a small pointed tool, like an awl, and gently push on the ball to free it up. Once the ball moves, the grease gun should work OK.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
pickle6415
10-19-2015 08:08 AM
4Xtruck
16
09-24-2015 09:38 AM
Quick Reply: Grease gun
