Got a few mods done this weekend
I finally got around to installing my XM radio receiver in the 4Runner. While I had the dash apart, I also added an extra 12v power outlet to the passenger side of the console.
My regular radio is a Pioneer FH-P4400 CD/Tape combo with IP bus input. The IP bus can be used to connect a Pioneer CD changer (the in-dash unit then controls the changer) or an aux input device. With a PIE adaptor, I can connect any line level input to that IP bus port. I used it to connect my Delphi Skyfi XM receiver to the IP bus port. Skyfi units use a cig lighter plug for power, yuck. I put an extra 12v power port INSIDE the dash so there would be no ugly plugs. I also used a ProFit vehicle specific mount to mount the cradle. The mount included with the Delphi "Car Kit" is weak and ugly. Please ignore the fingerprints all over the Delphi's screen .
BTW, XM is great. With the Delphi unit, I can move it from car to car or indoors, or even portable with the "boombox" product. It's definately worth the $10/month, especially if you like to listen to programming other than top 40 music (talk, comedy, truly alternative music, etc is available).
Here's the install:
Here's the extra 12v power port:
edit to add: Pioneer also makes an XM add-on receiver equipped with an IP bus port to connect directly to and be controled by radios like mine. It appears to be a nice product, but it is not "portable". Since I didn't want multiple XM accounts and wanted XM in both cars and the house, I went with the Delphi unit.
Chris
Here's the install:
Chris
Wow that looks sweet man. Very clean install.
I'm surprised how small that CB is underneath there.
Was the 12v mod pretty easy? You use Bob or Dan's write-up in the tech section?
Originally posted by Stump1883
Wow dude that is sweeet. Do you have a write up for that extra outlet that is awsome?
Chris
Chris
Re: Got a few mods done this weekend
I know you have the power issue dealt with, but as a tidbit of info for others, the lighter adapter is actually a DC->DC converter, it takes 12v in and puts 6v out. So youo HAVE to use it, you can't just cut it off and wire the Delphi straight into your power source.
But, I popped mine open and it _can_ be hardwired into a 12v system.
If you pop open the adapter (unscrew the nose piece, the gently pry open the case) you'll find a fuse inside and the step-down/regulation circuitry. Pull the spring-loaded nose piece and solder up a length of two-conductor 18 gauge wire ("lamp cord") to where the fuse connects and the side contacts, then snap the case back together.
Then you can wire up the adapter just like anything else in your system.
The lighter socket behind the dash in an interesting idea as well.
Congrats man! Nice install!
Re: Re: Got a few mods done this weekend
BTW, one thing I forgot to mention is the antenna installation. I positioned the antenna at the front of the truck right at the edge of the windshield. It's a mag mount and low profile (about .5" tall and 2" long). I threaded the wire (16gauge, maybe smaller) into the small "channel" between the window gasket and body. This is an open gap about 1/8" wide and equally deep. It goes all the way around the window. I followed that till I got to the bottom corner of the windshield, where I then threaded it into the engine compartment. From there, it went into the passenger compartment though the same hole my CB antenna coax is threaded through. After driving to work this morning (speeds of 35-70mph), the cable hasn't moved at all.
Chris
:bigok: looks sweet.... I took out the ashtray and mounted my CB in the same location. I did have to cut some plastic so it would mount flush. And also had to use a 90 deg ant. addapter. Did you as well??Or did you find one that is shallow enough to fit as is??
Originally posted by idahorunner
[BI did have to cut some plastic so it would mount flush. And also had to use a 90 deg ant. addapter. Did you as well??Or did you find one that is shallow enough to fit as is?? [/B]
Chris
Mtn,
Looks like you did some quality work there! I have the same ideas to mount a small monitor on my Pro-fit mount too as part of a carputer system.
Looks like Bob's write-up.
Bob
Bob
Originally posted by Bob_98SR5
Mtn,
Bob
Mtn,
Bob
I read your write-up today. You know, I think I read it some time ago and filed the info away in my brain without realizing it. When I opened that page today, it was like looking at my own truck.
Chris
TheBFA
02-15-2020 06:55 AM
