gearing
gearing
I have 97 4runner with 3400 in it would like to regear to run 33s i have 3.58s in there now from factory what gears would be good for on and off road use also what trans is in there and the gear ratio in it thanks for any help
Also if i found what i was looking for from the search i wouldnt be asking
i'm not sure if there's a 3.58 final gear ratio. have you verified it?
anyway, the needed final gear ratio for 33" tires would depend on the kind of offroading you'll be doing. some are happy with a 4.10 final gear ratio. others have the 4.30, some have the 4.56, while others have the 4.88
I have not verfied for sure but few friends that had toyotas seem to think that is right and as far as offroading i live in ohio we have off road park that is mild to wild so i just some thing that wohld be good for both
I doubt you have 3.58's.. I've never once heard of that gear ratio in this generation of 4Runners. You most likely have 4.10's. If you want to get closer to stock RPM's with 33's then 4.56's are good. If you plan on going any bigger than that though you might as well go to 4.88's. I have 4.88's with 35's and it's close to stock.
You might however want to find out your true ratio. If for some oddball reason you have 4.30's and you go to 4.56's you're going to be wasting money cus you and your 4runner wont be able to tell a difference.
One of the reasons im looking at regearing other then larger tires is was at off road park and didnt know that the breather tube fell off my rear diff and it sucked in water and gunk so i fixed the hose and drained and filled the rear dif and about a week ago noticd a clunking noise and checked it turns out that it iis the reae diff going bad so im like oh well i want to regear it and lock it anyways so i have a better reason now
What is the gear code on the tag inside the driver door?
If it is B02x, then you actually do have 3.58 gears !!
That will also tell you the stock tire size that came from the factory.
you can also double check the results from the above post by using your VIN in here:
http://www.toyodiy.com/parts/q.html
then choose "Powertrain/Chassis" then "Rear Axle Housing and Differential"
This is the first site that i have found that says i have 3.90s front and rear every other site says i have 3.58s in both either way the rear dif is about dead and they both need locked so im going with 4.56s and locker in front but havent decided on locker or spool for rear
i would recommend to lock the rear first and then check if you need to lock the front. also consider using a trutrac up front and a rear locker.
the front diff is a 7.5" diff and isn't as strong as the 8" rear diff.
<img id="ums_img_tooltip" class="UMSRatingIcon">
CV's are
I have 2003 3.4L V6 Toyota Tacoma Im running 315/75/R16 wild countries and was wanting to change my gear ratio it has the stock 4:10 gears in there now and was wondering what would be better the 4:56 or the 4:88 i put my truck in on a gear ratio calculater and it told me 5:29 so idk? can sombody help me with an educated answer please?
Is this 4runner a 2wd? Everything Ive read says that 3.58's only came in 2wd and
pre- runners. All 4wd trucks and runners had at the highest ratio a 4.11. and the lowest being 4.88.
If you are 2wd then stop talking about wheeling.
The 4runner is 4wheel and people on this fourm wonder why people cant stand this fourm prob cause of the person that is called thatguy plus when done with work it prob be better loking and go through what ever i want it to so it will be thank you
Go over to pirate and ask the same question and see what happens, this isn't the forum people don't like when they ask a gearing question and get hammered with flames..........
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
