Front diff bracket bushings - source??
Does anyone sell just the rubber portion of the front diff bracket bushings? Toyota only sells the entire bracket, which you need two, and they list for $110 each.
I'm talking about the rubber bushings seen in this vid (on the left at 0:22)
http://www.youtube.com/watch?v=8GZnYLfW1NE
my suggestion would be to look into the size needed rather than vehicle specific!!
as well you can look here to see if you can find the part #
http://www.tacomaterritory.com/wiki/...php/Parts_List
Ok, I neglected to update this week. Turns out the IPC shows "stoppers" for the top and bottom of the bracket. The bottom is basically a beefy washer. The top is a beefy washer with the upper rubber bushing grafted to it. 41653-35030 is the part number. The lower portion of the bushing is a part of the bracket, as stated in my first post. I'm going to have it back apart this weekend and I'll update with the findings, and whether just replacing the upper stopper improves the situation at all.
jerusry
10-19-2015 05:28 PM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
