flex fan
Old 05-27-2003, 09:22 PM
flex fan
I have a 88' 3.0
I know some people add flex fans to thier trucks, what is the benefit to these fans?
better cooling?
more power from not having an engine driven fan?
more chicks?
please tell!
Old 05-27-2003, 09:28 PM
instntset's Avatar
More chicks! More chicks! More chicks!
Actually I think they do a better job cooling becasue they draw in more air than the stock fan, depending if you set it up to be a pusher or a puller. If i remember correctly it is better to set it up as a puller....also they free up a few HP like you said not being engine driven
Old 05-27-2003, 09:40 PM
Erich_870's Avatar
Did you know that the more chicks you have in the rig, the better the gas milage?
Back on topic: My girlfriend's dad brought up a down side to electric fans. If your thermostate goes out you could be screwed. With your stock fan you don't have to worry. But if you watch your guages I think you would be fine.
Old 05-27-2003, 10:55 PM
UKMyers's Avatar
There are several advantages to the electric fan.
1) Little more power and better mileage because you are not turning that 15lb yes 15lb fan and clutch off your engine
2) You don't have to listen to the stock fan scream every single time you start the truck
3) More chicks
4) The truck does seem to cool better in hot weather when moving slowly and it's much more quiet when it comes than when the stock fan engages
5) If your a hardcore wheeler you can wire it to a switch so you can shut it off for deep water crossings
6) It's easier to change your belts if you have to.....okay that's digging pretty deep..haha
Some disadvantages
1) If you have some kind of wire failure you could overheat
And that's about it... .I don't know why you would be screwed if you lose your thermostat because the electric fan uses it's own built in thermostat with a probe that is inserted through the radiator. If your engine get's hot it's going to come on regardless
To give you some perspective on my experience the electric fan only comes on when you've been idling for a while or your in stop and go traffic. During normal cruise it will never run. I have better throttle response a bit more power and I got 30 more miles to my last tank of gas.
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
myotherrideisayoshi
09-29-2015 05:41 AM
voiddweller
09-28-2015 11:21 PM
oldblue
09-28-2015 04:07 PM
Quick Reply: flex fan
