Expert Needed Power Steering Confused!!!
Hey guys,
I am having a major PS leak. This is not the pump or resivor the previous owner replaced those. The leak come from a "BOX" on the lower passager side. This "dox" is mounted directly to the frame. The local parts place and the FSM nor the Haynes shows this box. What the hell is it? I lnow that the PS lines go into it however it appears that some other line run through this thing too. I tried taking it of to look at it What a bitch...I abandoned the project due to lack of line wrenches. I observed a little plastic piece on the bottom of this box where the PS is leaking from. Someone please give me a clue to what this is and if there is a rebuild kit avalable. For the experts...here is the VIN JT3VN39W4R0146743
Originally Posted by Teamsobaco
No one else has this thing in their truck?
Originally Posted by 4Crawler
The box on the passenger side is for the ABS brakes. It uses the power steering fluid to actuate the ABS.
So if the power steering fluid is low, would that cause any problems with the ABS? Mine seem to lock up rather quickly on slick or even slightly damp roads, and I know I have a power steering leak somewhere also.
Not sure, never had ABS myself, but one sure way to find out. Dump some ATF in there (not power steering fluid) and see if it gets better. May also be the load sensing proportioning valve on the rear axle. If you have the classic 4Runner "butt sag", then that fools the LSPV into thinking there is a ton of weight in the bed and it increase the rear brake pressure to compensate. However, if there is not really weight back there, that could make the rear brakes more prone to locking up.
Great thank you now we have established it is the ABS system..does anyone know how much it costs to rebuild/replace...this might expalin why I have to STAND on the breaks.
voiddweller
19
05-02-2016 09:10 PM
yourrealdad
7
07-21-2015 08:53 AM
